Results 1 to 12 of 12
    Registered User Four Rings
    Feb 26 2006
    Over 20! too many plant pots!
    Earth
    What do you want in it??
    Ok going to be doing one of my tech threads for engine building/stroking set ups for B5/B6 motors now that I have all the pictures of everything I need (Brenden helped too...THANKS)
    What do you guys want in the thread?
    Bare in mind that the thread will list parts for sale (gotta pay bills etc) but it will not be advertiser driven but more TECH driven as that is what I enjoy doing....
    Veteran Member Four Rings Nebone's Avatar
    Jan 21 2006
    6MT BT Avant Ti
    RI
    Re: What do you want in it??
    Use of measuring tools
    Ibis White 2008 Audi A4 2.0T Avant 6MT S-Line Titanium APR Stage 3
    Deep Sea Blue Pearl 2010 Audi A4 2.0T Premium Tip
    Dolphin Grey 2005.5 Audi A4 2.0T Avant 6MT *Sold after 7 years of ownership*
    Goodwood Green Pearl 2002 Audi A4 1.8T Sedan Tip
    Santorin Blue Pearl 2001.5 Audi A4 1.8T Sedan 5MT *Sold after 9 years of ownership*
    Veteran Member Four Rings zrowcool's Avatar
    Nov 09 2006
    2000 B5 A4 Quattro / 00 F-150 XLT S/C
    Bronx, NY
    safe clearances such as piston to cylinder, piston rings to cylinder, main bearings to crank, etc. It'll make it easier since all the info would be in one place.
    2000 A4 1.8tq
    Running only on Amsoil fluids.
    Amsoil products at wholesale pricing... Ask me how!
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by zrowcool View Post
    great point.
    Issam, I know you wrote a DIY about filing rings. I would put that in there. If you showed how to apply the main and rod bearings with torque specs and how to use plastigauge
    - Clint
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    clearances would be good, but depending on the alloy compound of the piston the clearances will differ based on the expansion properties of the alloy.
    then you have ring gapping based on the ring type and so forth.
    i kno i am being devils advocated, just trying to make sure someone coming into this thread not knowing anything doesn't use all of these specs like the "Bible".
    Now knowing what it takes I'd like to have been able to read a thread that includes.......
    piston ring end gapping
    piston to cylinder wall clearances
    main bearing clearances
    rod bearing clearances
    removal of cam's (safely)
    timing of cam's
    bore and hone specs (will differ based on ring package choice)
    the more info the better. Let me know if you need any pictures of anything as my engine is completely disassembled for the next week or so.
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Oct 27 2007
    2001 Golf 2004 A4 USP
    In the lab
    Issam, let me know if you need more pics... I'm building a few motors right now, one of them being an 06A
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    i would be interested if you included what goes into doing the vr6t swap.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by B5A4Kevin View Post
    hes already shown everything you need for that, and that is OT
    - Clint
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    More information about increasing displacement with the TDI 95.5mm crankshaft.....I've researched everywhere and I've only been able to minimal information. It'd be great to see a displacement chart like this for the TDI crank:
    Quote Originally Posted by 317ssayzarc View Post
    Displacements are as follows:
    81mm bore x 86.4mm stroke = 1781cc (stock)
    81.5mm bore x 86.4mm stroke = 1803cc
    82mm bore x 86.4mm stroke = 1825cc
    82.5mm bore x 86.4mm stroke = 1848cc
    83mm bore x 86.4mm stroke = 1870cc
    83.5mm bore x 86.4mm stroke = 1893cc
    Now when you add a 92.8mm stroke crank to you engine you have the following displacements:
    81mm bore x 92.8 mm stroke = 1913cc
    81.5mm bore x 92.8mm stroke = 1937cc
    82mm bore x 92.8mm stroke = 1961cc
    82.5mm bore x 92.8mm stroke = 1985cc
    83mm bore x 92.8mm stroke = 2009cc
    83.5mm bore x 92.8mm stroke = 2033cc
    And also, what type of machining (if any) is necessary for using the newer generation crank shafts
    It'd be cool to help the community expand its knowledge of engine building, especially since more and more people are doing it these days
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    engine builds are good too, and i dont know what hte scope of this write-up will consist of, but i know i struggle with the tuning/fueling aspect of the engine once the engine is complete...
    what tune or SEM, injectors, intercooler, TB, turbo, downpipe, intake system.... etc..
    -josh
    -josh
    Feb 26 2006
    Earth
    Not going to do that...
    this is strictly 4 cylinder 1.8T's
    What else?
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    use of the correct assembly lubes and whatnot while installing various pieces to get the correct torque on aftermarket bolts would be good. plastigauge is something i havnt seen mentioned much before. maybe a comparison of different throttle bodys that can be used.
