Results 1 to 17 of 17
    Sep 02 2008
    US of A
    Noise While Accelerating
    Hey everyone,
    Got a little problem that has been going on for a while now.
    Everytime I put my foot on the gas pedal, I always hear some kind of noise possibly from the front suspension or engine (not too sure where it's coming from but I narrowed it down to those two).
    The noise also gets louder as the RPM gets higher, but once I release the gas pedal, the noise suddenly stops.
    Could it be the front axles going bad?
    Thank you in advance for any tips and info I could get.
    Senior Member Three Rings Spykce's Avatar
    Aug 06 2008
    Indiana
    Re: Noise While Accelerating
    What kind of sound? Is your car an automatic or manual? 1.8 or V6?
    Current Car: 2000 A4 1.8TQ Frankenturbo Build | 2012 Passat TDI
    History: C6 A6 4.2, B7 S4, Mk V GTI, Mk IV GTI Vr6, Audi 80, Audi 4000 Q, B5 A4 1.8TQ x 5, B5 A4 V6, Mk II Cabriolet x 4, B5 Passat 1.8T, Mk II Scirocco, Audi TT 1.8TQ, Mk III GTI Vr6, C5 Allroad 2.7T x 3, '86 VW Quantum Wagon
    Nov 09 2007
    Alaska
    Valve tap? Low Oil to lifters? I have the same noise, its just on acceleration too.
    Registered Member One Ring luchoA4's Avatar
    Apr 11 2008
    2001 A4 1.8T
    las vegas
    Hey there!
    I have the same noise at 1st. And 2nd. And when I shift 3rd. The noise is gone is the exact same thing that happens to you. I just did some work on it (well not me actually) replaced: water pump, timming belt, (not that it matters but the important things I replaced both front axles and the 3 motor mounts so I thought I was done with the noise, but guess what, is still there, so 4 sure is not the axles I have to take it to the shop again this week so if I find what is it I let u know or if u do plz let me know
    Jan 09 2008
    88'90quattro 98'passat quattro 05. Usp a4 571whp 97 a8 00 TT 99 Passat 2.8l 5 speed 99 Passat 1.8.
    haverstraw ny
    is it diesel engine like noise??
    Apr 11 2008
    2001 A4 1.8T
    las vegas
    u know, is more like if something was loose over there, but im pretty sure there's not, cuz my mechanic did a lot of work on it, and the noise was there b4 he got his hands on the car, and it was there after, and he changed, axles, timing belt, rotors... so idk
    Registered Member Two Rings mwebb's Avatar
    Jan 25 2009
    98 2.8 A4
    central pa
    im having the same issue but only in 1st gear. GOTTA love when ur gas car sounds like a diesel
    98 A4 2.8
    1976 Jeep CJ7 with 14" suspension lift
    Feb 13 2009
    98" AUDI A4(B5) 1.8T
    KITTERY, ME
    dang i have the same problem...i think...does it sound like a knocking noise( clack clack clack clack) that increases as you accelerate and when you stop it quiets down but still there its like towards the back of the block??? one of my buddies say that it could be rod knock but im not to sure...but i went to you tube and typed in rod knock and heard some videos and it came out just like we hear...clack clack clack...lol...its just a suggestion
    Sep 02 2008
    US of A
    I think my problem comes from the axles. Haven't replaced them but I narrowed it down. I'll update once I replace those axles.
    ZeRo_R17 are you talking about this kind of sound: http://www.youtube.com/watch?v=x9LJP1mw0es
    Because that sound is happening during idle and when it comes to my case, the sound is there only when the car is in motion.
    Veteran Member Four Rings Jibberific's Avatar
    May 22 2008
    az
    cam chain tensioner maybe?
    {99.5 Avant}
    Veteran Member Three Rings spyder101's Avatar
    Jan 25 2009
    some where in the U.S.
    I have the same noise as well. I put a stethoscope up to the turbo and that was where the rattle was the loudest. I have a new turbo laying around so, I'm going to install it anyways just because the car has 142k miles on it. While I'm there I'm also going to make sure that the exhaust manifold bolts are tight beacuse, they will start to loosen up at the back section as well. I'll let you guys know how it turns out.
    Jan 25 2009
    Alright, I took the turbo out and found that the wastegate flap was loose, which created the ratlle. Replaced the turbo and no more noise.
    Veteran Member Four Rings down_n_dapper's Avatar
    Sep 13 2012
    Adelaide, AU
    MAAASIVE BUMP
    anyone find the issue? mine seems to make a rattle noise under acceleration only in 1st and second, would love to know what the issue is!
    Maintaining a 12 year old Audi is about as expensive as Charlie Sheen's coke habbit.
    00' Silver B5 1.8TQM
    | Wheels coming | Depo Projector Retrofit (clear lense) | BC Coilovers |
    Kenwood Headunit + 4" F +Jl 6" R + 10" Sub | TFSI Coils |
    | 2.5" turbo back exhaust | K04 RS6 Hybrid Turbo|
    Veteran Member Three Rings disturbed_audi's Avatar
    Oct 13 2012
    mk4 jetta 2.0, 2003 R6 Ltd Edition, bagged body dropped 92 S 10
    Indiana, PA
    Quote Originally Posted by ZeRo_R17 View Post
    oil pick up tube is clogged I done a ton of searching about this late last year. the 1.8t are extremely prone to sludging up clogging your pick up tube.. you either need to change or clean your oil pick up drop subframe oil pan and clean/change ..
    01 Audi A4 QMT 17"avus, atp testpipe, forge splitter
    92 S-10 manual 3 inch body drop, bagged tucking 3 inches on 18's
    03 Yamaha R6 powercommander
    mk 4 2.0 vw jetta
    Established Member Two Rings AnotherMonday's Avatar
    Feb 04 2013
    Cobwebs and old tools.
    Southern GA
    Forgive my noobiness, but does the 2.8 have a pick up tube? Similar sounds here...
    Veteran Member Four Rings Believer's Avatar
    Oct 24 2011
    New Jersey
    Quote Originally Posted by AnotherMonday View Post
    I'm fairly certain every car will have some variation of a pick up tube. The pickup tube is where oil from your oil pan is pulled into the oiling system.
    Oct 13 2012
    Indiana, PA
    Quote Originally Posted by Believer View Post
    yeah i'm with believer I don't have a 2.8 but you have to have some sort of pick up tube if i'm not mistaken I believe you have two. if you have a chain on metal sound at low and high oil pressures its one of two things pick up screen slugged or your cam chain tensioner and/or chain is on its way out. and I am 100% certain that 2.8's have two cam chain tensioners and chains.
    easiest way to tell if its the pickup tube is to hook a oil pressure gauge up and check your oil pressure.
    EDIT: found a general idea of what pressure you should be running compliments of walky_talky
    Generally, the 1.8T's top end will start getting noisier once the oil pressure gets below 20psi or so.
    Just checked my oil pressure after my drive home to be sure:
    Idle: 26 psi
    2k: 55 psi
    3k: 70 psi
    4k: 80 psi
    5k: 95 psi
    mk 4 2.0 vw jetta
