Results 1 to 4 of 4
    Jan 06 2009
    washington, d.c.
    cam tensioner gasket
    I'm new to the group, and I have read several posts on this issue, but still not quite sure about what I need to replace these gaskets (and half moon seals?) on an ATQ 2.8 30 valve engine.
    I am in the process of replacing the timing belt, tensioner, water pump, etc. and I noticed some oil has leaked down the front of the driver's side cylinder bank and is affecting one of the coolant hoses in a not so wonderful way.
    Looks to me like the valve cover gasket needs to be replaced, and I would like to change the gasket under the cam chain tensioner too, but I don't really have time to order the tool for compressing the tensioner.
    Some people say it's a deal breaker, must have tool, and some say you can get by w/o the tool.
    Would be interested in hearing from anyone who has done this himself.
    Thanks very much!
    Veteran Member Three Rings V8weight's Avatar
    Nov 16 2008
    Hudson, WI
    Re: cam tensioner gasket
    You can get it out without the tool, but may god have mercy on your soul if you decide on that route. I've done it without the tool, but you really really shouldn't. I dont believe the compressor is all that expensive. when you buy a new cam adjuster, it comes with one, thats where I got mine.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Try a post in the North East regional forum and I'm sure you'll find a fellow AZ'er locally who could lend you the tool. Worth a shot!
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jan 06 2009
    washington, d.c.
    Thanks for the input.
    I wound up springing for overnight shipping from Baum Tools in Florida. UPS is getting most of the dough in this transaction! Was rather shocked at 65 dollars and change (each) for the valve cover gaskets from the local Audi dealer.
    I'm sure I could have done better on the web.
    Tool should be here this afternoon. It's gonna be Christmas all over again!
