Results 1 to 31 of 31
    Veteran Member Four Rings TonyD's Avatar
    Aug 11 2007
    2012 135i tuned+meth'd
    California
    3rd gear is messed up
    So for the past 6-8 months shifting into 3rd gear would grind ONLY while I'm going WOT. About 3 weeks ago it would grind every time going into 3rd, and that lasted for just a day. It went back to normal the next day. Now for the past 4-5 days it's grinded EVERY time going into 3rd. Is this just the synchro? And what all needs to be replaced? I'm not good with trannys so any help is greatly appreciated.
    Jun 30 2007
    Raleigh, NC
    Re: 3rd gear is messed up
    Quote Originally Posted by Tony@Autobahn View Post
    sounds like a synchro. mine was doing the same thing, though i had multiple issues with mine lol
    if you're in first gear - say in a parking lot... and you accelerate, then let off the gas and just engine brake - do you get a whine like when in reverse?
    if you do, start shopping for a new tranny NOW instead of waiting. otherwise just get on JHMotorsport and get the rebuild kit. comes with a video so you can DIY
    12.5 best ET -- 113 best trap
    The Awesome™
    BetaAlphaTau Member #42
    Dec 07 2008
    Chicago Il
    try changing your tranny fluid i had the same problem in my B5 S4 and that solved it. i just changed the fluid and like 4 days later there were no more grinds.
    Aug 11 2007
    California
    I was going to do the tranny fluid and hope that solves it.
    B6Lovin, I'll try that tomorrow morning. I'm hoping my tranny isn't messed up. =(
    Jun 30 2007
    Raleigh, NC
    i doubt it. for one you're not pushing over 2.5 times the stock power through yours, and for another i drive mine like a complete shit head at times.
    all my burnouts, "drifting", axis spins, drag racing, and faster than necessary shifting didnt help.
    The Awesome™
    Dec 07 2008
    Chicago Il
    true true, i'd still rather change the fluid first you never know you might be lucky like i was and its not that expensive neither...good luck :)
    Aug 11 2007
    California
    Quote Originally Posted by B6Lovin View Post
    Me too. I treat my car like shit at times. And it returns the favor by breaking down.
    Jun 30 2007
    Raleigh, NC
    yup. that's how it goes though... i didn't build the car to drive it easy, and i have said time and time again that i will NOT go easy on it just because i know something is wrong (short of the motor). in the case of the transmission - i knew it was on its way out, so i made sure she went down fighting... it was going to cost about the same either way
    The Awesome™
    Oct 29 2005
    10speed
    San Francisco, CA
    I blew my trans on the K03
    - Clint
    Jun 30 2007
    Raleigh, NC
    valid point lol. my car only has 60k on it though.... showed signs of death around 52k (right after my... ahem.. new motor/BAT hahahahaha)
    The Awesome™
    Aug 11 2007
    California
    I'm at 56k with 20k being driven by me. Worst 20k of this cars life.
    Aug 11 2007
    California
    So I go out to my car this morning and theres a small little pool of liquid under it. It has a pinkish tint to it? Please tell me thats not tranny fluid...
    May 24 2007
    Southern California
    did you touch it? smell it?
    Kyle
    2.0L Revo GTRS Eliminator
    Veteran Member Four Rings coowhip's Avatar
    May 11 2008
    Columbus, OH
    That sounds like tranny fluid to me. You might just be low on fluid and have a seal out. Check your levels asap!
    Aug 11 2007
    California
    It didn't smell like anything. I smelled and smelled, just smelled like the ground haha.
    Veteran Member Four Rings A4 TSCHUSS's Avatar
    Apr 24 2005
    E55 AMG, CTS-V
    Jacksonville, Florida
    Sounds like your pentosin pink coolant probably leaking from the back of your head since your rear coolant flange is about to take a shit. Better touch it though and see if it is coolant or oil (tranny fluid)
    ~David~
    Gone but not forgotten 437whp on 93 octane and washer fluid injection A4 12.2 best ET, 12.3@119 best overall
    480whp/500wtq E55 AMG 11.6@120
    CTS-V 9.6@148
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Quote Originally Posted by A4natomical View Post
    does it taste so sweet?
    -Doug
    May 24 2007
    Southern California
    Sometimes you gotta do what you gotta do.
    Kyle
    Aug 11 2007
    California
    It's coolant. Just don't know where it's coming from. Sick. So now leaking coolant AND a tranny problem!
    Dec 03 2005
    2 pedals 1FG
    connecticut
    As David said. Coolant is probably your rear coolant flange on the head. See DIY at the top of this forum.
    Trans.... Start by flushing the fluid and putting some nice Redline MT90 in with a quart of Heavy ShockProof. If that does not fix it then your syncros for 3rd gear are on their way out as Daniel mentioned. Same symptom I have with my 1.8T trans but it did not manifest itself until I went GT28RS from bone stock. Issue was even worse when it was cold out and the trans gear oil was cold and viscous.
    Okay. back to figuring out logistics for India. Gonna be an awesome trip.
    -Doug
    Aug 11 2007
    California
    Sick. Thanks doug. I'll see what's going on in the morning.
    And what's the worst that could happen if I keep driving with a messed up 3rd gear synchro?
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Yes, and you wind up grinding 3rd gear down to nothing and having to replace 3rd gear as well. (expensive...)
    If you wind up rebuilding your transmission (IF this truely is the problem... syncros that is). I recommend all new syncros for all the gears. Might as well do 'em all while you've got it apart. $400 for the syncros. Talk to Jay at JHM as Daniel mentioned.
    -Doug
    Jun 30 2007
    Raleigh, NC
    yeah, if shit keeps going the way it has been you me clint and tony are gonna be the 4 tranny swap/rebuild DIY gurus... oh well, cest la vie (or whatever those frenchies say)
    The Awesome™
    Oct 29 2005
    10speed
    San Francisco, CA
    true, and if the 80 trans work we can add another one to the arsenal of possible transmissions
    - Clint
    Jun 30 2007
    Raleigh, NC
    yeah let me know about that asap. if you think it won't work lmk that too - i need my car up and running last week
    The Awesome™
    Veteran Member Four Rings DonnieDark0's Avatar
    Mar 02 2009
    bs 54
    Long Island NY & Kent OH
    wut ended up happening?
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    I was wondering what route you chose for your tranny. Did you find a used one or you're rebuilding yours? And yeah, c'est la vie is right LOL.
    Veteran Member Three Rings whiteUSPflow's Avatar
    Feb 22 2008
    2004 USP 1.8tQ, 2003 RS6
    Richmond, VA
    Dam syncos that sux. That happend to me also with my third gear. I was also on my K03.
    USP CLUB MEMBER #97
    APR tuned K04-Carbonio-Forge-Podi-Stasis-034 Motorsport-RAI motorsport
    Unitronic tuned RS6
    Apr 24 2005
    E55 AMG, CTS-V
    I hate 3rd gear, mine has been screwed up for a while now. Sometimes it is ok sometimes it grinds real nice and doesnt want to go in while trying to shift fast while winding the piss out of it.
    ~David~
    CTS-V 9.6@148
    Jun 30 2007
    Raleigh, NC
    Quote Originally Posted by FourRings80 View Post
    swapped a b5 1.8 tranny into my car. mine is awaiting money for a full rebuild
    The Awesome™
    May 21 2007
    Florida
    where can you source a new tranny? ive got a 6spd and my first gear syncro is messed up. thanks.
    2018 Navarro Blue Q5
