Results 1 to 3 of 3
    Jan 28 2005
    02 S4
    soCALI
    Question replacement 355mm rotors
    Is anyone running specials on stoptech replacement rotors right now? Are there any 2 piece rotor otptions that will work with the 355mm stoptech caliper and bracket?
    Jan 28 2005
    02 S4
    soCALI
    Re: replacement 355mm rotors
    Anyone ever try running Alcon rotors under stoptech calipers and brackets? Is it correct thinking that as long as the rotors are the same width and diameter, as what orignally came in the kit, they will work? Where are bbk'er getting your replacement rotors from?
    Veteran Member Four Rings Tifosi's Avatar
    Apr 27 2004
    Pacific NW
    Try Zeckhausen: http://www.zeckhausen.com/StopTech/c...les.htm#Rotors.
    StopTech was purchased by Centric. And IIRC, owns Power Slot also.
