Results 1 to 10 of 10
    Veteran Member Three Rings Grangalan's Avatar
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Stg III S4, TB keeps popping out of alignment
    T1demonT1 Just finished installing my clutch and putting the engine back into the car, Doing trial drives at first we were in limp mode, after clearing codes we went past 5 psi but after a second of high boost the car fell flat on its nose and basically went into oh shit cant go past 20 mph mode.
    Upon checking the codes we came up with
    P1173
    Throttle Actuation Potentiometer Sign.2 Signal too High
    P1544 - 35-10 - - - Intermittent
    16507 - Throttle Position Sensor (G69): Signal too High
    As well as P1545
    We did a Throttle body alignment but right when we get on it, it does the same thing. High boost, then BAM , back on its nose into 20mph only mode with the similar codes. Does the Throttle body need some miles on it with "normal" driving before getting on it? Any suggestions?
    --Black 2001.5 -S4- 10secS4 Tuned
    Veteran Member Four Rings Sleeeper X's Avatar
    Nov 20 2007
    01.5 S4
    The city with tall BUILDINGS!
    Re: Stg III S4, TB keeps popping out of alignment
    Stop using a worm clamp
    l gotta-- l gotta get
    a form from a scientist.
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    What does that have to do with my codes. I'm not leaking boost
    Veteran Member Four Rings t1demont1's Avatar
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    last night i drove around for about 15 miles, then hit it and it worked fabulous. I did atleast a dozen pulls that night over the course of about two hours. I thought the car was fine then shut it off for 10 minutes, start to come home and hit it and it its super limp.
    The side effects of this limp are:
    the car cant go over 1100 rpm
    ecp, traction control, and abs lights come on
    some code for tb malfunction
    BetaAlphaTau Member #40
    1999 2.0 hx35 dbw conversion
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    sounds like a massive boost leak..
    try this, check your TBB, do not release the TBB, slide your fingers underneath the bottom and see it is still seated. It might be seated from the top, but it might be loose on the bottom.
    B5 S4 AWE Stage 3 - sold
    Sep 27 2007
    Stage III 2001.5 S4
    Clearwater, FL
    Rajan, as t1demon described above.it boosts fine but all over sudden it just jerks as the throttle body goes into some sort of limp mode.you can't rev or anything. With a boost leak it would at least let you build rev slowly.
    Jun 14 2007
    2000 S4
    Connecticut
    sounds electrical.... did you plug the MAP sensor back in on top of the TBB?
    May 08 2007
    1999 1.8tqm gt3071r
    Orlando, FL
    found the issue, the plug to the tb came loose and was causing the issue. car is beastin full stg3 now :D
    Nov 23 2007
    Columbus, OH
    sometimes its the simplest things
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    get the VIDEOS now!!!
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
