Results 1 to 6 of 6
Thread: trans question
    Veteran Member Three Rings Audi05s4's Avatar
    Oct 17 2006
    Hockessin, DE
    trans question
    i have a question for you guys. im currently upgrading my clutch and fly wheel to a aluminum light weight fly wheel that is going to be apprx 13.5 lbs and a stage 3 clutch should i be feeling faster accelerations and quarter mile times?
    daworldisyours.com/forum<----check it out!!!!
    Nov 28 2007
    04 S4,Volvo P1800,03 Silverado
    Massachusetts
    Re: trans question
    I've done the same with the Clutchmaster set up and its not a noticeable difference... you may get a couple tenths of a second off your quarter mile and 0-60. Only place it feel quicker for me is on highway 6th gear pulls at 70+ mph. I notice it the most when it comes to drivability. Rev matching is very easy and smooth. I like the clutch feel better then stock, and you can feel the engagement point more. if you need a new clutch its definitely better then stock.
    04' Nogaro S4 - 19" BBS RS-GTs - H&R Coilovers - Hotchkis RS4 Sways - 4500k HID fogs - JHM solid shifter trio -JHM intake manifold - JHM port matched intake spacers - JHM longtube headers - JHM tune - Fast Intentions resonated catback - Snub mount - Vag mods - hardwired V1 - Clutchmaster Stage 3 clutch & 13.5 lb flywheel - Euro B7 RS4 steering wheel - Cayenne Big Reds - stern engine mounts - Stern upper control arms - K&N panel -
    Oct 17 2006
    Hockessin, DE
    Re: trans question
    thank you
    Veteran Member Four Rings serumk's Avatar
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Re: trans question
    Quote Originally Posted by ginkof View Post
    Clutchmasters only seems to have the clutch for the B5 on their website. Am I looking in the wrong place, or do they actually carry the clutch for the B6?
    Thanks.
    Oct 17 2006
    Hockessin, DE
    Re: trans question
    have to call them
    Dec 31 2008
    2002 A4 quattro
    Kansas City
    Re: trans question
    Quote Originally Posted by Audi05s4 View Post
    have to call them
    Thanks.
