Results 1 to 10 of 10
    Sep 14 2006
    Removing rear brakes and rotors
    1. Is there only one 13mm bolt holding the rear caliper in place?
    2. When I get the caliper off, will the rotor just slide off or are there bolts that I need to remove?
    3. Will this work to compress the rear caliper?
    -Thomas
    Current: /S3
    Previous: B6 A4/B8A4 Avant
    Sep 23 2006
    Houston TX
    Re: Removing rear brakes and rotors
    There should be two bolts. The bottom one is a big PITA. I removed the rear shock to gain access, a couple of other people have shaved off the hex bit to fit a socket wrench in there. The rotor will "slide" off but depends on how rusted it is on there. Might take a good hammering to break it loose. I'm not sure about the caliper tool since I replaced my fluid.
    Veteran Member Four Rings ryannorthcott's Avatar
    Jul 10 2008
    2002 A4 1.8T Quattro
    Kelowna BC
    ^what he said about the bolts is true, you pretty much have to remove the lower strut bolt to get a breaker bar in there in order to loosen the bolts.
    now that cube tool can be used with great difficulty, i used it and eventually got the piston screwed in. however, if i were to do the job again i would definitely invest in rear caliper retraction tool like the one on ECS.
    when i used the cube thingy, i just clamped it down into the piston with a c-clamp and while tightening the clamp i turned it with a little socket extension.
    hope that makes sense
    two thousand two audi a-four quattro five speed
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    Like the guys said above, there are two recessed allen head bolts, but I believe they are 8mm, one is longer than the other so take note. Removing the strut is the best option to get the lower bolt as well. Ensure the allen is in as far as possible or you will strip one and have a hole other problem to deal with. I believe it is recommended to replace these bolts as well, which I did when I did my rears. The Shwabben brake tool is much easier to use as well. Good luck
    Veteran Member Four Rings akaEsCo01's Avatar
    Dec 08 2006
    Jersey
    Best bet for that rear allen bolt is a stubby allen socket. I tried with a regular allen socket with no availe, the stub too some strength but it was much easier. I only took out one bolt and pulled the carrier back far enough to angle the rotor off. I had over 90K when I did this and it case off pretty easy.
    Sep 14 2006
    Alright I think I get the picture now, thanks for all of the helpful info guys and I think I'll definitely go buy the ecs caliper tool!!
    -Thomas
    Current: /S3
    Dec 03 2008
    Orlando, FL
    Dunno if I'm late w/ my 2 cents, but I just did my rear brakes and have to say it was easy!!! Surprised me. I used a bolt buster spray, waited 5 min and the back allen bolts came off w/ a tap of a mallet on a breaker bar (used the car's jack handle). If you go to an automotive parts store like Autozone or Advance Auto, you can rent the caliper tool for free w/ a deposit.
    The 2 most important things are first, take your time. Second, read any forum here and other Audi forums before. The info I got from these guys is great.
    BTW, when I did my brakes I took pics of every step. I have basically step-by-step of a rear brake job if anyone wants to put a DIY together. I know there are DIYs out there, but these pics are real good.
    Feb 15 2008
    AWE powered B6 1.8T
    Severna Park, MD
    ^^Post up the DIY with the pics, this topic comes up almost every week...
    Buncha motorcycles
    Memphis, TN
    its not that hard just use your head to get to the bottom bolt...
    FYI ecs just sells a rebranded harbor freight tool + $20... i was a sucker
    APR Stage 2/AWE Intake
    Oct 19 2005
    ontario
    you dont need to remove the bottom bolt to get the rotor off, once you have the top one off just tap the carrier back about 1/2 inch and the rotor will then come off. just reverse the procedure to move the carrier back
