Results 1 to 7 of 7
Thread: Now what?
    Dec 26 2007
    1999 Panoz AIV roadster
    New Market, MD
    Now what?
    I have a 2008 S4 Avant, tip, with about 12,000 miles on it; bought it new. I have been driving it regularly until about 3 days ago cause needed to use SUV. So it sat in the drive for 2 days I think. I started it once yesterday and ran it for about 30 seconds just to move it. Today, when I tried to start it, it almost wouldn't fire. It took 3 tries to start it and when it did start, it was missing and shaking like crazy. I revved it just enough to keep it going and it finally gradually smoothed out and has been OK since on restarting several times today. The CEL never did come on. Any ideas what that heck that was about?
    1999 Panoz AIV
    Aug 06 2008
    wayne pa
    Re: Now what?
    could be a alot of different things go to pepboys and get an obd code puller and see if u get anything
    Nov 19 2008
    San Jose, CA
    Re: Now what?
    Coilpack perhaps??
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Re: Now what?
    Its a new car. Call the dealer for a loaner and have roadside assistance pick it up.
    Veteran Member Four Rings ieatfishburitos's Avatar
    Jan 10 2007
    Earth
    Re: Now what?
    yep call dealer and tell them it's broken.. They should pick it up and give you a loaner.. Don't invest anytime investigating, it's there problem to fix... New car warranties can be fun!
    2013 White 911 4S
    Gone but not forgotten:
    2015 Sepang Blue S3 - 1 of 5 exclusive edition
    2004 Nogaro Blue S4 Avant w/ Noggy interior
    2005 Moro Blue S4
    Veteran Member Four Rings drew's Avatar
    Jul 27 2004
    E60 M5 Gone: 996TT stage 3, E46 M3, B6 S4
    Orange County
    Re: Now what?
    possible a bad tank of gas...
    Veteran Member Four Rings Justincredible's Avatar
    Jul 24 2008
    chicago
    Re: Now what?
    If the issue continues to happen then make sure you get it to the dealer. If this happened just once and you want to make your self feel better that there is nothing super wrong with your car. Then
    If it is cold where you live the car runs super rich in the cold weather. So if you start your car only for a few seconds move it and shut the car down in cold weather you can damage the plugs. Even one or two times doing this can cause an issue. Also depending on weather the car was out side you may have had the throttle body adaption running. This has happened to me before. The car will sputter for a sec and then run fine.
    Now Im not saying that either of these DEFFINITLEY happened just helping give a few reasons why it might have happened. As I said if the car is still having the issue then get it to the dealer. If it was a one time thing you should be ok
    If you don't have haters, then you're not kicking enough ass.
    JHM powered 12.2 On the JHM Tune With Launch Assist for the Automatic JHM Nitrous kit/JHM headers all this in a Automatic.
    And lastly for the grammar police that are bound to step in
    I came here from Germany in the 6th grade. I could not read or write a lick of English. I am working to get better. Thanks and sorry. I always try to edit my posts for the best grammar and easiest reading.
