Results 1 to 15 of 15
    Veteran Member Three Rings slow ride's Avatar
    Apr 20 2005
    New Hartford, IA
    RS4 pressure plate flatness?
    Can someone set a straight edge across a new RS4 pressure plate for me. Take a picture of it or measure any cupping if possible. If someone knows the LUK part numbers of the RS4 and S4 pressure plate I'd take that also.
    Thanks,
    Ed
    00' Laser red S4 RS6 hybrids e85
    02' Corvette ZO6 383 TT 1012whp 990wtq
    02' Tundra
    SOLD 93' AWD Talon 523whp 486wtq
    Apr 20 2005
    New Hartford, IA
    Re: RS4 pressure plate flatness?
    Even checking on a stock pressure plate would help.
    02' Tundra
    Senior Member Two Rings Splinter's Avatar
    Jan 31 2008
    B.C., Canada
    maybe email someone from vast or jhm or something like that, they seem to be very helpful and probably wouldn't mind giving you a hand
    2001 S4 6spd black on black- GIAC, Borla, BBS CH, CarPC, rattle can white trim, 034 snub w/ cage, ebay silicone hoses, AWE DTS, obligatory RS4 grill... dreams of Stage 3...
    2000 Audi A4 1.8TQM - RIP March 9/08
    Apr 20 2005
    New Hartford, IA
    I'll try some of them, but I didn't want to bother them. Can someone check a used stock pressure plate?
    02' Tundra
    Apr 20 2005
    New Hartford, IA
    bump
    02' Tundra
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    Not sure what you are trying to achieve.
    But I can tell you this. The S4 replacement LUK clutch cover and the RS4 LUK clutch cover look cosmetically identical, the finger heights are the same and the plate is the same height.
    The ONLY difference is a higher clamp load on the RS4 thus a little more pedal effort and higher torque capacity.
    Hope that info helps.
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Apr 20 2005
    New Hartford, IA
    Well as most would think the pressure plate friction surface should be flat, but in my experiance of working on all makes and models I never seem to find a flat used pressure plate. Even on cars that were not beat or had very few miles on a aftermarket clutch the pressure plate always seems to be cupped or warped. If you set a straight edge across the plates they always have a gap towards the inner edge.
    I have a used RS4 plate and was wondering the condition of it is what I was getting at. It is warped a little, but if most of the plates are that way after being used it doesn't make sence to pitch it. I don't have many people around me with S4's so it's hard to find examples local to me.
    02' Tundra
    Aug 24 2005
    Lathrop, CA
    Quote Originally Posted by slow ride View Post
    I usually visually inspect if I ever reuse one (only in our in house cars and close friends, never in a customers car)
    Post up a pic so I can see how it looks.
    I would be more concerned with resetting the SAC mechanism.
    Apr 20 2005
    New Hartford, IA
    The surface is in decent shape. It didn't have any heat marks on it and I could still see some of the lines in the material they commonly have when they are turned flat at first. I already went over the surface with a 3m abrasive disk and die grinder to scuff up the surface a bit. I also reset the SAC in my press which was easy on my shop press.
    Now if I could only find just the friction surfaces I want to reline the disk with I'll have a nice budget setup. I'll post some pictures later.
    02' Tundra
    Aug 24 2005
    Lathrop, CA
    You should be good to go man. I have put some pretty gnarly ones back in friends cars with great results. A messed up SAC seems to be the only issue that may arrise. If you clean it up chatter shouldn't be a problem.
    Account Terminated Four Rings
    2001 S4 GT28, 2001 S4 168K
    Long Island, NY
    they are flat, you can always have a pressure plate rebuilt if you want to reuse it and while you are at it you can increase the clamping load by 15%-30% on the pressure plate
    Apr 20 2005
    New Hartford, IA
    I'm totally with you on them being flat when new, but just wish someone would have a known good used one to check. Seems like they always get a little warped from the heat cycles combined with the pressure being applied at the same time. I need to pm you about getting a disk relined if possible. Does anyone know if the LUK pressure plate numbers are for the s4 and rs4 and if there is any difference from the parts Audi sells?
    02' Tundra
    Aug 24 2005
    Lathrop, CA
    Audi sells LUK parts they just have a Audi PN on them and not the LUK pn. The S4 and RS4 pressure plate are different PNs.
    Apr 20 2005
    New Hartford, IA
    Different clamp load yes, but I'm sure they use the same cast friction surface which is why I didn't care if someone measured a s4 or rs4 plate. Just seems like the mark up on the rs4 parts is not in line with what you can buy the LUK repset s4 parts for. I'd pay a little more for a heavier pressure plate, but not >2 times. I'm sure if you get the LUK parts for the rs4 it would be a lot better deal.
    02' Tundra
    Long Island, NY
    also FYI i don't know how many people know this but the 2000 S4 came with a lighter clamp load on the pressure plate then the 2001. It was a revision that superseded the dealer part number and the 2000 Pressure plate is no longer being made.
    You can actually take a 2001 Pressure plate and increase the clamp load to greater then the OEM RS4 PP
