Results 1 to 20 of 20
    Junior Member Two Rings
    Aug 26 2008
    S.E. Michigan
    Question Engine Shutdown On Freeway!!!
    Was on the freeway and almost at my destination (about 45 miles away) when i lost power for a second. hit the gas a bit more and power came back for a second before the car completly shut off. Gas guage was close to Empty but light hadnt come on yet. called my boss to come bring me some gas guessing my guage was off. tried starting it again before putting gas in and it started for a second and died. After putting gas in, car would start and idle would stumble around for a sec before dying (reminded me of trying to start a car without MAFS plugged in). Got it towed to my job (Discount Tire) were they said they couldnt hear my fuel pump come on although my boss said he heard it come on when we were on the freeway. SOOOO what i need is some imput from some audi savvy people. Thanks
    MY18 B9 S4 Stage 1
    00' B5 S4 Stage 1+
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Re: Engine Shutdown On Freeway!!!
    could be a boost league. Unplug the MAF and see if it fires up.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    May 18 2007
    01 Laser Red 6MT, 13 Touareg TDI
    Baytown, TX
    what kind of voltage are you getting? could be your alternator.
    Aug 26 2008
    S.E. Michigan
    Voltage is fine and im pretty sure my turbos are gone or on there way out. Car has been running pretty damn slow for a while and both turbos have a bit of shaft play so im guessing there isnt any boost anyway but that shouldnt keep it from turning on and running.
    MY18 B9 S4 Stage 1
    00' B5 S4 Stage 1+
    Veteran Member Three Rings s42k5b's Avatar
    May 31 2008
    New York
    Quote Originally Posted by D1tuner View Post
    Uhh ok...Well you could have had a smaller boost leak that turned into a massive boost leak..
    00' Cactus, GIAC,H&R coilovers,original K03's for the time being..
    Veteran Member Four Rings Boris's Avatar
    Dec 20 2005
    District 7
    would check if it runs without maf plugged in..maybe your fuel supply line ruptured..although I think thats unlikely, but you could maybe not have enough fuel pressure..perhaps something is causing you to not have enough fuel pressure.
    Dec 07 2008
    Chicago Il
    sorry to hear that bro i had a 01.5 S4 chipped coming back from stl (like 250 miles from chicago) i was trying to do a top speed run and after i passed 170 the car just shaked for a second...turned off and turned back on and all i saw was white smoke coming out of my exhaust (blew both the turbo's) had a nice 600 towin fee back to chicago too :(
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Quote Originally Posted by ALEN2488 View Post
    k03's or ko4's
    B5 S4 AWE Stage 3 - sold
    Aug 26 2008
    S.E. Michigan
    Car has K03's. I took access panel cover off in trunk to the fuel pump and when i turn the key on i hear nothing from the fuel pump? i checked it for volatage and only got 1.5 volts.....im pretty sure (voltmeter set on 20 DC). Fuel pump maybe?
    MY18 B9 S4 Stage 1
    00' B5 S4 Stage 1+
    Established Member Two Rings RenegadeEngr's Avatar
    Jun 15 2008
    San Francisco
    I've had the alternator die on the interstate and run out of gas on the interstate, I believe those are Alternator Symptoms.....
    2001:Silver:S4:DarIntake:ABT Chip
    Mechanical/Fluids Engineer
    May 22 2007
    East Bay, Ca
    You may want to crack your fuel line at the intake while someone turns the key on teh ignition to the number two position to see if you get fuel. If not, check fuse 29 (I think) for the fuel pump and if it is okay and you get no gas out of the line, it is more than likely your fuel pump.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    alternator?
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Veteran Member Four Rings Klum00's Avatar
    Nov 27 2006
    Baltimore, MD
    Quote Originally Posted by wdbdy2000s4 View Post
    is that the national boost league or american boost league?
    Quattro Kings
    @quattroking
    Currently in the garages
    2016 S6 . 2014 RS5 cab . 2013 Q5 . 2008 A6 avant
    2002 TT ALMS . 2001 S4 . 1992 UrS4 . 1974 100 LS
    1952 DKW RT125 . 1939 DKW F8 . 1937 DKW F7
    Veteran Member Three Rings jukesandz's Avatar
    Oct 10 2008
    '00 Audi S4
    NE
    I don't think it would be the MAF. I was talking to AudiSportB5S4 and when he had MAF problems, power would cut off at 4k rpm's, but I'm pretty sure he drove it back to his house fine, and it started fine.
    I guess it might be worth a try to unplug it.
    Jul 28 2008
    01.5 S4, 09 Touareg, 88 Cabriolet 16vT
    Pittsburgh PA
    well if no fuel pump, no fuel... so it's either that it's getting no power, no fuel or not functioning... you've filled it with fuel... so check voltage (at the battery, to the panel, to the pump) and then consider a bad pump or relay...?
    Senior Member Two Rings dpdaudi's Avatar
    Apr 10 2007
    01.5 S4 Stage 3 RS6 Vast tuned
    Bountiful, Utah
    If it's not a fuel or electrical problem, check all your charge and intercooler piping. If one has come loose or has a leak the car will sometimes start for a couple of seconds but wont run. I hope it's just something stupid like this so you don't have to spend $$$$$. Post what you figure out.
    Veteran Member Three Rings kingofqueenz788's Avatar
    Jan 11 2007
    audi%20s4
    NewYork, NewYork
    get the codes from the car, thease cars always have intermittent problems n will show up on a scan tool or vag and work your way closer to the problem from their.
    Established Member Two Rings black_bi-turbo's Avatar
    Sep 23 2006
    2004 S4 Avant, BMW Z4
    Sarasota, FL.
    Happened to my car just before christmas. Get one of your buddies to help you out, and while trying to start the car have them lightly punch the fuel tank and it should probably start. If thats the case, its definately the fuel pump.
    Hope it helps and good luck.
    Oct 29 2005
    10speed
    San Francisco, CA
    Quote Originally Posted by Klum00 View Post
    ahahaha nice Aaron
    - Clint
    Oct 08 2008
    MA
    You've been around here long enough... you should know I was talking about the american boost league.
