Results 1 to 12 of 12
Thread: car shaking
    Senior Member Two Rings joeS407's Avatar
    Dec 20 2007
    2000(B5) S4 Hibiscus red
    naperville
    car shaking
    hay just want an opinion, when im stopping from 60+mph pretty hard the whole car shakes. i know its not my front or rear rotors and all the bolts on the brakes are tightend to factory spec... what could be causing this
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: car shaking
    Could be warped rotors. Unless you did just change them. Bad tie rods and/or control arms could also do that.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Re: car shaking
    How do you know its not your brakes? Did you replace both the roters and pads recently?
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Dec 20 2007
    naperville
    Re: car shaking
    Quote Originally Posted by 2k1audiS4 View Post
    yes i did about a month ago
    2000 s4
    Fairfield, CT
    Re: car shaking
    just because they are new doesnt mean they cant be warped. get the rotors warrentied and try again
    i heart my s4
    Established Member Two Rings b6quattro's Avatar
    Jul 08 2008
    '03 A4 1.8t Quattro 5sp
    Orlando, FL
    Re: car shaking
    '03 A4 1.8tqm - Brilliant Black on Tan
    Apikol Snub
    S4 Rear Sway
    Cold Weather Package (perfect for FL!)
    Sirius Sat. Radio
    Veteran Member Four Rings RolledMySTi's Avatar
    Jul 06 2007
    2001 S4 Sedan Laser Red
    San Jose, CA
    Re: car shaking
    I would jack up the front of the car, take both wheels off and give the whole front suspension a good look over.
    01 Laser Red S4 Stage 3 | Vast Fueling | Clutchnet 6 Puck Disk with RS4 PP | APR Downpipes | Aluminum Flywheel | Neuspeed Exhaust | SRM Side Mounts | ECS Pulley Kit | RS4 Airbox | UUC Short Shifter | ST Coilovers| Samcos | AWE DTS Bar | JHM Center Diff | 034 Track Motor Mounts + Street Trans Mounts | Apikol blue rear diff mount and bushings | Areomotive Fuel Pump | ECS 2.0T Coil Conversion | Hooked on Meth
    Dec 20 2007
    naperville
    Re: car shaking
    Quote Originally Posted by b6quattro View Post
    that is a thought, ill look into... but because of upcoming track days i think i might just upgrade the brakes all around anyways
    Active Member Four Rings Jung's Avatar
    Jul 07 2007
    Tempe, AZ
    Re: car shaking
    rolling around in any snow lately? snow/ice buildup on the inside of the rims can cause nasty vibrations too
    '07 S4 Avant - The Purpetrator
    there's just something about her, maybe it's her awful accent but i've always wanted to tonguepunch her fartbox - cruz
    Dec 20 2007
    naperville
    Re: car shaking
    no snow near me just rain
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: car shaking
    Quote Originally Posted by RolledMySTi View Post
    Do this and go from there. Shake everything around. Bad suspension parts will be very apparent this way.
    08 S4- Stock SOLD
    Veteran Member Three Rings seadoo4563's Avatar
    Aug 10 2007
    Annapolis,MD
    Re: car shaking
    Quote Originally Posted by mholme View Post
    thats the master tech way
