Results 1 to 18 of 18
    Registered Member Two Rings
    Jun 23 2008
    Orange, CT
    2.8 gas mileage question, winter weather aside
    hey guys my 2.8 30v has been running like shit lately..well not literally running like shit, it runs very strong but gas mileage wise. i commute to school, it is 30 miles each way. i do very little to slim city driving because, everyone usually comes to me, besides errands.
    The problem is that im getting about 250 miles to a tank, on a 16.60 gallon tank and driving from full to until the light comes on. i am running in the 65-80 mph area on and off of cruise control.
    I have the intake mod done, with k&n filter. I change my oil regularly, and i have an exhaust with the resonator delete. I have run the sea-foam, changed the fuel filter, and ran some fuel line cleaner through the system.
    I have a cel for the intake, but thats about it.
    What could the problem be? i am running my snow tire setup on my stock rims, i dont feel like they would cause me to get such bad mileage though.
    Oct 06 2004
    Minnesota
    Re: 2.8 gas mileage question, winter weather aside
    My A6 gets just as shitty mileage. I am putting new plugs and fuel filter soon. Your problem is definitely not the snow tires.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Feb 27 2005
    North Wales, PA
    i'm not positive but this is my take on why fuel efficiency goes down in the winter.
    1) gas quality goes down because they add more additives.
    2) engine burns more fuel during warm up. since its cold, it takes longer to warm up
    3) increase in air density
    Veteran Member Three Rings drexplode's Avatar
    Jul 19 2007
    2016 M3 - maximum hooligan
    Michigan
    i have not changed my fuel filter and my driving is city grandma style. I try to coast as often as possible...
    my computer says i'm averaging ~18-19 MPG.
    Mileage = 118k
    Trans = Auto
    No mods.
    "A turbo boost gauge the size of a fat spaniels face! - Jeremy Clarkson
    Feb 27 2005
    North Wales, PA
    i'm still getting 21-22 in the city. I usually get 23ish in my avant driving like a gramdma
    Oct 06 2004
    Minnesota
    Quote Originally Posted by Poopie View Post
    1.8T though...
    Instagram r_michals
    Established Member Two Rings AWD Mike's Avatar
    Oct 19 2008
    '14 Tacoma TRD Sport | '14 SQ5 Prestige
    Richmond, VA
    I too have the 2.8 30V Manual.
    I have been tracking my mileage, I was getting roughly 19 city. I replaced the plugs, plug wires, air filter and catalytic converters, and now, I am getting about 25 in the city. I recently made a 400 mile trip to NY and back, getting about 29.5 on the highway doing 80 the entire time.
    P.S. I run premium in my car -- 93 octane. Gas is also key, where do you usually get your gas?
    Veteran Member Four Rings A4 Effort's Avatar
    May 28 2007
    '99 A4 2.8 / '07 A4 S-Line Avant / '09 A4 S-Line 2.0
    Mt. Airy, MD
    I was getting around 320 miles to a tank in my 2.8. Since adding my S/C, i'm now getting around 280.
    You should still be getting better mileage than 250 a tank though. Have you tried changing your plugs? It should go without saying, but make sure your tires are properly inflated as that can be an inhibitor too.
    | 2007 Ibis Ti S-Line Avant | APR Stage 2+ | APR HPFP | 034 HFC | Forge DV | Stasis Exhaust | KW V1 Coilovers | SPC Adjustable Control Arms | 19" MRR GF6s | 034 TIP | 034 Sway Bar & End-Links | K&N Drop-In | Deval CF Front Splitter | Relak CF Sideskirts | S4 Recaros | TT-Sline MFSW | P3 Vent Gauge | RS4 Grille | RS4 Fog Grille Mod | RS4 Pedals | RS6 Shift Knob | OEM+
    Jun 23 2008
    Orange, CT
    my tires are properly inflated, and my plugs only have about 20,000 on them. I replaced a ton of stuff on the car when i bought it. I am not about to spend a grand replacing the cat's though.
    i get my gas at sams club or mobile. since gas went down i have been running premium but i have not seen much of a difference.
    im completley puzzled, idk i am upgrading my car in two years when i am done with college but until then i dont want my everyday commuter to be getting shitty mileage.
    even with gas at 1.55 here it is still alot of money down the drain.
    Oct 06 2004
    Minnesota
    29mpg in a 12v!? WTF! I want that.
    Instagram r_michals
    Established Member Two Rings TJR178's Avatar
    Mar 27 2008
    Erie, PA
    Quote Originally Posted by AWD Mike View Post
    That almost sounds too good to be true. That's even better than the factory says.
    I average 19 city, 23 highway. Same set-up.
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    i ussually get 19mpg about 50%city 50% highway, at 65 im averaging 27-28 on flats, at 55 im averaging 31-32, the faster you drive the more the mileage goes down cuz the more throttle u need to maintain your speed
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Nov 30 2008
    1998 Audi A4 2.8QM
    MA
    Quote Originally Posted by TJR178 View Post
    I just got 24.5 mpg on a 40 mile drive on the highway. I was going about 75 on the first 30 miles and then went down to around 65 and the mpg went up a bit. over 25 mpg going 80 mph seems really high, is it fwd?
    just quoted the wrong one, meant to respond to awd mike. I'm guessing the awd refers to your car?
    1998.5 A4 2.8QM
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by A4Rob View Post
    I averaged 26-27mpg highway, or ~23-24mpg/tank with my 12V.
    That was with a SRI, GoodYear Triple Treads, and a warped/busted flywheel.
    EDIT: Permanent P0401 EGR code, I didn't know how to fix it then. Had it been fixed I probably could have picked up some more MPG.
    I did get like 16mpg once, but I got bored one Saturday afternoon and swapped the stock injectors for a set of 350TPI injectors. It ran slow as hell but the torque curve was soooo smooth.
    Established Member Two Rings Flash's Avatar
    Oct 13 2006
    Earth
    I have a v6 30v and I get 27 with all-season tires on and 25 with winter tires and I drive 62 kms a day. The ice-tires definitely reduce mileage, at least on my cars and I waited till December to switch where it was about -24C (-11F) for a few weeks. Good fluids and good gas I suppose?
    Senior Member Two Rings EuRoSp1c's Avatar
    Nov 04 2008
    Jersey
    i only get 200 in my 1.8t... so 250 is better then what i get so be happy... lol
    Veteran Member Three Rings xraycer2012's Avatar
    May 28 2008
    B8.5 S4
    Mine gets an over all average of 21.6mpg with mostly city driving or stop and go during rush hour. That's also with snow tires, before I moved to philly I was getting an overall average of ~24mpg with the stock continental tires.
    ‘23 RS6
    '14 S4 Nogaro Special Edition - Sold
    Veteran Member Four Rings 2001A6's Avatar
    Sep 17 2008
    Stuff
    St. Charles, MO.
    30v 2.8Q A6, darintake + K&N panel, Remus non-res cat-back, VAGCOM A4 engine recode, and 00032 tip code. With the cold weather, Im getting between 17 and 20 going back and forth to school, 10-15 min drive, mixed. In the summer, highway is between 24-28 depending on speeds(29 once), and school or just driving around is about 21. And thats with a lead foot.
    ~Matt.
    - PES Supercharged 01 A6 2.8Q
    -01 A6 4.2
    -04 Touareg 4.2
    -89 951
    - 99 Viggen
    -06 GTI
    -04 W8 wagon
    -01.5 S4
    The C5 Union
