Results 1 to 7 of 7
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    oil burning when cold starting
    Hi guys,
    A week ago, my min oil level light came on. I've checked the level and notice that it was true. So, I've added 1/2 pint I checked again and finnally add the other 1/2. The level on the stick was perfect. I drove the car 3-4 times for 150 miles total. One night, after started the car with my remote for 10min, when I came out, there was a lot of smoke around my car with a burned oil smell. I drove the car for one mile and notice no more smoke out the exhaust, I think it stopped instantly when I reved a little more than idle. Since that time, I did'nt take my car to much and this morning, the exact same thing happened when I came out... the same smoke, the same smell and it stopped after a little driving... My car is still under warranty but I want to make sure the dealer will not accord this trouble to my mods... I went 2-3 times to the dealer for warranty jobs and they never talk about my mods. Do you have any idea of what can be that problem?
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings mtbrider's Avatar
    Oct 31 2005
    Virginia
    Re: oil burning when cold starting
    as long as your dealer is cool with your mods it will be ok, i've never been lucky with my dealer
    Some fast things and some slow things
    ~Josh~
    May 01 2008
    Winter
    ...other advises?
    May 01 2008
    Winter
    May 01 2008
    Winter
    Please guys, give me your advises...
    Established Member Two Rings agelosa4's Avatar
    Jul 05 2008
    greece
    turbo
    audi a4 2.0t quattro- rs4 hofele-dtm rear bumber-ic-76mm exhaust ecu remap etuners-bsr intake-xyz coilover-19s wheels audi r8. rs4 injectors-gt3071 set up 450ps
    Veteran Member Three Rings fitch303's Avatar
    Jan 03 2008
    Columbus, Ohio
    Check your coolant at the reservoir and make sure there is no oil in it. Check around the turbo for leaks, also check your intercooler pipes for excess oil. Some dealers don't make a big deal about a warranty repair on a modded car as long as the warranty fix has nothing to do with anything aftermarket. In your case you have a modded engine and a tune which pushes more psi than stock. It sure will be an uphill battle, good luck!
