Results 1 to 3 of 3
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    Oil burning when cold starting
    Hi guys,
    A week ago, my min oil level light came on. I've checked the level and notice that it was true. So, I've added 1/2 pint I checked again and finnally add the other 1/2. The level on the stick was perfect. I drove the car 3-4 times for 150 miles total. One night, after started the car with my remote for 10min, when I came out, there was a lot of smoke around my car with a burned oil smell. I drove the car for one mile and notice no more smoke out the exhaust, I think it stopped instantly when I reved a little more than idle. Since that time, I did'nt take my car to much and this morning, the exact same thing happened when I came out... the same smoke, the same smell and it stopped after a little driving... My car is still under warranty but I want to make sure the dealer will not accord this trouble to my mods... I went 2-3 times to the dealer for warranty jobs and they never talk about my mods. Do you have any idea of what can be that problem?
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Senior Member Two Rings sti4now's Avatar
    Oct 21 2008
    Turbo M3
    NC
    Re: Oil burning when cold starting
    this is normal for audi's when cold
    ECS stage 3 S4, APR stg 3 fueling, APR K04 turbo kit, Iforged Aero 19" wheels, Reiger front bumper, ABT sides, Samco TBB, JHM FMIC, H&R coilovers, Porsche stage 4 cayenne BB kit, AWE DTS, RS4 Clutch, SS kit, FORGE DV's, JE design Heckspoiler, ECS shiftknob w. suede boot, VDO boost gauge
    01 Stage 3 S4, AWE turbos/fueling, H&R race springs, O.Z Superleggaro's, JHM FMIC, JHM solid SSK, SSAC TBE, Samco TBB, VAST stage 3 clutch, VDO boost gauge.
    May 01 2008
    Winter
    Are you sure? I'looks and smell like an old Lada I've seen in Cuba...
