Results 1 to 18 of 18
Thread: rear brakes
    Registered Member Two Rings
    Nov 11 2008
    Roanoke, Va
    rear brakes
    Hey everybody 1st time poster here. I need some advise on brakes. I need new rear rotors and pads. Would it be wise to upgrade my rear brakes to S4 brakes on my 05 quattro with a sport package. Or just replace my rotors and pads with oem or equivalent. Thanks
    Jun 24 2008
    E46 M3
    Woodinville WA
    Re: rear brakes
    You'd also need the calipers as well if you switch since the S4 uses Vented rotos. Not sure the benefit would justify the cost in your case. That's your decision to make though........but it would be kinda cool I have to admit
    C
    Nov 11 2008
    Roanoke, Va
    Re: rear brakes
    I found the calipers for $225 for the pair. Does that sound like a decent deal?
    Senior Member Three Rings 02alltoad's Avatar
    May 27 2008
    04 S4,Allroad,00 911,00 a6 4.2
    Arvada, Colorado
    Re: rear brakes
    Quote Originally Posted by 4RingsFreak View Post
    where at if i might ask, thats a good deal
    Nov 11 2008
    Roanoke, Va
    Re: rear brakes
    ebay. please no one else buy them.
    May 27 2008
    Arvada, Colorado
    Re: rear brakes
    the hanger that you would need is p/n 8E0 615 425 B by the way if you need it. left and right are the same
    May 27 2008
    Arvada, Colorado
    Re: rear brakes
    lol i need a6 rear calipers dont worry. just make sure that they are for the vented rotors alot of the listings say there for an a4/s4/rs4 jut to get people to look at them and buy them without questions.
    Veteran Member Three Rings cjonesgo's Avatar
    May 22 2007
    02 A4 Avant 1.8t qm, '74 Vespa
    oakland ca
    Re: rear brakes
    3.0 brake conversion is a nice option as well. Uses stock 1.8 caliper and a different carrier(hanger) to adapt to the larger rotor. I can't remember diameter off the top of my head. Look in the stickies, there is more info there. All you need is new rotors, pads (which you would need anyway) and 2 carriers.
    [CENTER]02 A4 Avant 1.8tqm Dolphin Gray
    Blackout Grills | S4 Bi-Xenons | 3.0 Brakes | RS4 Rear Swaybar | Bilstein Sport Shocks
    K04 | REVO | TT225 Injectors | Apikol SMIC | 034 HFC |
    May 22 2007
    oakland ca
    Re: rear brakes
    i wrote previous post assuming you have 1.8t engine. if you do it right you don't even have to bleed system!
    May 27 2008
    Arvada, Colorado
    Re: rear brakes
    Quote Originally Posted by cjonesgo View Post
    there 255mm and the 1.8 is 245mm both are 10mm wide and solid and the s4 is 300mmx22mm vented. to convert to the s4 rears you would need calipers, carriers, rotors, and dust shields but thats just what i can think of of the top of my head at 1 am lol
    May 22 2007
    oakland ca
    Re: rear brakes
    Quote Originally Posted by 02alltoad View Post
    go alltoad!
    i couldn't even remember diameter and it's only midnight here! i even did this upgrade to my car! bed time i guess.
    Feb 07 2008
    Koeln, Germany
    Re: rear brakes
    I've heard that some late model 1.8ts came with 255mm rears.
    2005 A4 Avant USP 6MT Q
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: rear brakes
    For the price of S4 rears you might as well just buy Alcon rears for cheaper.
    -Doug
    Oct 16 2006
    Naperville
    Re: rear brakes
    B5 S4 rear brakes??? No wonder its so cheap. I would wait out and find b6 s4 rears.
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: rear brakes
    B5 S4 rears won't fit the B6 chassis.
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: rear brakes
    b6s4s have vented rears wheras alcons are not
    APR Stage 2/AWE Intake
    Dec 03 2005
    2 pedals 1FG
    connecticut
    Re: rear brakes
    Quote Originally Posted by Papachristou View Post
    Alcon rears are roughly $800 (new)
    B6 S4 rears are roughly $1200-$1500 (new)
    You play the game of how much money is worth it.
    Rear brakes do not do that much on the B6 A4. OEM B6 A4 has 68% of the braking done up front and 32% done out back (brake bias). Therefore, vented versus solid rear brakes is almost a mute point for street usage. One is not going to get the rear brakes hot enough to benefit from a vented set-up.
    -Doug
    Buncha motorcycles
    Memphis, TN
    Re: rear brakes
    agreed, just pointing it out for the OP
    if and when i get $$$, im getting alcons f/r either 328 or 355 fronts, i havent decided yet
    BTW, havent a few of the alcon rears had trouble with stretching the ebrake cable ? i thought i read a post on that but i could be mistaken, probably install error
