    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Center cluster - couple questions
    Does anyone know how to disable the "beep" that it makes. IE: low on gas/low on coolant/low oil pressure? It is driving me CRAZY since my oil pan doesn't have the sensor I can't connect the cars sensor to it meaning that I get 3 loud ass beeps every couple minutes while driving.
    Is there any simple fix? I could care less if the display stops working, I can't read it anyway..Any fuses I could pull or anything? thanks for any help..
    Also, has anyone completely just removed this? i am wondering about this since I am going to need to run multiple gauges and was thinking of doing everything digital through this display rather than cluttering things up.
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Center cluster - couple questions
    anyone?
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    i think if you unplug the middle wire in the middle that runs to the display it wont do it anymore but leave the outside 2 for the tach and speedo. dont quote me on that though i could be wrong
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Here is a pic of the back of the cluster. The beeping comes from the cluster I believe. If you tape the one that looks like a small speaker it should almost totally remove the sound.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Feb 28 2007
    04 a4 USP ; ATS
    hmm..okay ill have to do that. thanks. anyone have any idea about running digital gauges where the driver display goes? Is there a way to disable the driver info display?
