Results 1 to 20 of 20
Thread: Meth Kit
    Established Member Two Rings kmoney's Avatar
    May 11 2008
    2000 audi s4
    Meth Kit
    I have a B5 S4 with a giac tune and I'm going to install my awe twin 1 that should be coming in tomorrow. I was thinking of my next upgrade to be Meth Injection. I called up Greg at SSPtuning about his meth kit and he said it would run me about $600 all together including the tune and I'd see gains between 40-50hp at the crank. What do you guys think of meth injection on K03's and the hp gain?
    Senior Member Three Rings eliTTe's Avatar
    Arlington, VA
    Re: Meth Kit
    if those numbers are honest, I'd go for it thats a lot of hp. if you think about it, a good stage 2+ has 350bhp. that meth kit would put it around 400bhp!! but I'd like to see some dyno numbers
    Then: 1985 Audi coupe GT, 1990 Audi 90 sport, 2000 Audi S4 stage 2+, 2002 Audi TT 225.
    Now: 2011 Audi S4
    Veteran Member Four Rings JDM EJ1 95's Avatar
    Feb 28 2007
    01 Nogaro S4 Stage 3
    chicagoland
    Re: Meth Kit
    basically what youre getting with a meth injection is the ability to run a racefile on standard pump gas or close to it.. thast why youre gaining a decent chunk of power..
    meth is a good mod but MAKE SURE to get a custom tune so you can use it to its full abilities.
    Nogaro 01 s4
    24v 2.9L VR6. 6466. Pump gas 10.7 @ 132
    620whp 93octane
    806/767 whp/wtq on C16
    10.4 @ 136 C16 (bad slipping clutch)
    138mph best trap with slipping clutch.
    May 11 2008
    2000 audi s4
    Re: Meth Kit
    yeah I would get it tuned at SSP
    Veteran Member Four Rings S-Power's Avatar
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: Meth Kit
    where would someone get a custom tune for k03's ?
    Veteran Member Four Rings BlkdoutS4's Avatar
    Jun 22 2007
    2001.5 S4
    Santa Cruz, Ca
    Re: Meth Kit
    Quote Originally Posted by S-Power View Post
    JHM could probably hook you up
    '01.5 Silver B5 S4 - Follow my build here: http://www.audizine.com/forum/showth...4-Build-Thread
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: Meth Kit
    Quote Originally Posted by BlkdoutA4 View Post
    Jay probably could but I doubt he wants to waste his time on a k03 tune. Idk
    Veteran Member Three Rings Go_S4's Avatar
    Mar 20 2007
    Nor Cal
    Re: Meth Kit
    ^ i doubt he would turn your business down... just contact him ..
    Jan 11 2008
    034 Stage 3
    CA- San Jose
    Re: Meth Kit
    Ill be asking him about this when he has time and isnt to busy
    Hes on a lot of projects and new things...
    Veteran Member Four Rings awd2ks4's Avatar
    Aug 25 2008
    2000 S4, Blown LS2 240sx hatch, LS3 240sx vert, 02 wrx
    Santa cruz
    Re: Meth Kit
    i talked to jay about this once before, he said he can do a custom tune with meth for about $600-650
    Active Member Four Rings 00s4slvr's Avatar
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Meth Kit
    im thinking about getting a meth kit also. what do you guys reccommend first,
    1.) a meth kit or
    2.) coilover suspension
    im stuck between the 2??
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Re: Meth Kit
    coils
    2010 Brilliant Black/Magma Red S4
    Sep 22 2008
    b7 a4 2.0T 6MT
    Nj
    Re: Meth Kit
    yeah and alos would a meth injection be safe to run on those little baby k03's?
    Veteran Member Three Rings ubermidget's Avatar
    Dec 08 2006
    Boston, MA
    Re: Meth Kit
    anything to do w/ k03's isnt too safe especially at high boost levels.....if you wanna keep your iat's low it might help preserve the life of your turbos if you dont boost the hell out of it. just my .02
    EPL Stage 3 Aquamisted
    Veteran Member Four Rings Rated S's Avatar
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Meth Kit
    Quote Originally Posted by ubermidget View Post
    Meth will lower your IATs significantly.
    SoCalS4.com/Repair - For All Your Delicious B5 S4 Tuning/DIY Needs
    Don't like me? Feel free to email me and tell me all about it - [email protected]
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Re: Meth Kit
    Quote Originally Posted by kmoney View Post
    Greg is the man! i would o it and efentially get the t00n from him, trust me you will see great results!
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Re: Meth Kit
    Get meth and an MBC, run 19 PSI for about 1000 miles and then have an excuse to go bigger when your turbos blow.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Veteran Member Four Rings 1997gtx's Avatar
    Sep 14 2006
    14 GLI
    Re: Meth Kit
    Go with the Meth and let Greg install it.
    It's good for your cylinder heads, and you'll pick up some good HP -- even on K03s.
    Don't forget what colder temps will do -- even at 17psi.
    It's like running the perfect CAI. The lower IATs alone are worth it.
    --Adam
    Have questions? E-mail me.
    Jun 14 2007
    2000 S4
    Connecticut
    Re: Meth Kit
    Greg's the man. Go for it :)
    Apr 02 2007
    '01 S4 '94 D21
    Studio City, CA
    Re: Meth Kit
    Quote Originally Posted by 1997gtx View Post
    --Adam
    Correct, W/M is good to run regardless of a tune.
    Your cylinders will be cleaned with the w/m, as well as lower iats are always better, regardless.
    But if you want actual hp, it will need to be tuned.
