Results 1 to 2 of 2
    Veteran Member Four Rings Charles's Avatar
    Jacksonville
    Frame/Unibody Damage
    Ok, so I was looking at a used S-line A4 and noticed they said there was previous frame/unibody damage. Does that simply mean it was in an accident or that the frame was bent and that it's gonna drive all wonky?? It says the title is clear and nothing about salvage.
    What do you guys think? Do I need to see if it drives ok or would you avoid it no matter what?
    Aug 06 2008
    Canadia
    Re: Frame/Unibody Damage
    only way to tell is put it on an alignment rack and see if it was put back to spec.
    the B5 S4 is like the mafia... there is only one way out!
