Originally Posted by
Emperoryder
Well,
A little background, my car has close to 130K at the moment, engine is in bad shape, the tiptronic is slipping and jerking. The value of this vehicle is minimum and had this car for a while and would like to keep it as sentimental value.
I'm looking to start a aftermarket automotive business and need a shop car to represent my company with. We we will be renting out shop bays, so we won't be doing too much of the mechanical side of the business, but should do well in selling aftermarket retail products.
I want to do something different than others and make it stand out, that's why I'm not really thinking of doing bolt on supercharger or turbocharger.
I will be building the car from ground up, rebuilding the motor to the right compression for boost and putting the adequate transmission and rear end, losing weight by various different lighter weight products, roll cage, wheels, wide body fenders, and all the little aesthetic goods. Through sponsors, tears, and blood. I have different cars to drive, so this car could sit around and be built for several months.
Therefore, I'm trying to see what would be different and outrageous and not too crazy that I can't accomplish it.
ok, I see where you are coming from and I have a suggestion for you .
First, get ready $50K for a ground up build. I am not saying you will need to spend all $50K but set that as a budget.
I recommend you have your engine built to become a bullet proof long block.
Then put a GT35R twin scroll turbo on it.
this power build will take a lot of work because many things you need will be custom. However, you will make big power and you will be very unique in the B6 3.0 world. You will also need to spend a lot to get everything right the first time. Tuning won't be much of an issue......
For the interior, if you want OEM finish, get a set of European RS4 seats or Recaro CS seats, whatever your pick.
Exterior wise, i don't know. are you a low rider?
