Results 1 to 13 of 13
    Veteran Member Four Rings ConroeS4's Avatar
    Oct 27 2008
    Montgomery TX
    Yay! I'm excited!
    I just bought Siemens 380cc Fuel injectors from manhertm. Going APR 1+. I saw the write up on how to install the fuel injectors, but from what I understand it requires an adaptor, which he is sending with the injectors. Are these simple to install?
    Thanks
    And thanks again manhertm on the great price!
    2001.5 Audi S4 2.7T 6spd Santorin Avant
    Stage 2+
    ABT tuning, Milltek exhaust, SSAC downpipes, JHM short shifter, RS4 grill, All silicone hoses, Michelin Pilot Sport A/S Plus's, 034 street motor and snub mounts, Darintake, 12" Alpine Type R
    www.TexasAudiGroup.com
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    Re: Yay! I'm excited!
    15-20 min is it... not hard.. he's prob sending you spacers for the fuel rail since the siemens injectors are a bit longer than factory... the spacers are for the bolts that hold on the fuel rail... enjoy the 1+. .i kno i do!
    CO
    The only thing I'd watch for to is the injector o-rings. I had to replace mine when putting in the TT225 injectors. The install was very easy, but I noticed some fuel seeping out after the install so I replaced all of the o-rings.
    Also, make sure you don't drop one of the fuel rail bolts into the engine bay. It'll be a b*tch to find and get out.
    Quartz Gray '11 S4 Prestige || Sprint Blue '06 S4 Saloon - Sold || Denim Blue '02 A4 1.8T - Total Loss || Laser Red '98.5 A4 1.8T - Sold
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    APR, ECS, and my tuner don't recommend those for APR - let me know how they do. I'm curious to hear if it's true or not (idling issues, etc.).
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Oct 27 2008
    Montgomery TX
    Quote Originally Posted by kwimberly View Post
    On the ECS website it says the will work fine for them.
    Stage 2+
    May 03 2008
    Orlando
    What ECS website are you reading?
    "Seimens - 380CC Injector Set - Set Of Four ES#6663
    - NOTE - Not compatible with APR Stage 1+ software learn more"
    http://www.ecstuning.com/stage/edpd/...bcategory=Fuel
    Kevin W.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    I find that genesis are better because of the dual cone spray, but thats just my 2 cents..also with apr, the tt225 injectors seem to be the best for there software...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Oct 27 2008
    Montgomery TX
    Oh damn you're right. Crap I already paid. What should I expect from them?
    Stage 2+
    Feb 07 2008
    just the a4
    northeast pa
    i have the siemens injectors going on ten months now and they are great!
    Veteran Member Four Rings mrbacardi35's Avatar
    Sep 18 2006
    Fresno/Los Angeles, CA
    it is true in experience, but is only for 2002 model b6 a4. i had the genesis and it was throwing codes for being lean so my tuner reimbursed me for the genesis and i just purchased the apr/tt 225 injectors and everything was good since then.
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    Doesnt manhertem have the tt225 injectors for sale as well? Try to grab those
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    Feb 07 2008
    just the a4
    northeast pa
    i believe his name is manguyen... and yeah, he has the injectors... shoot him a pm and he'll hook ya up w/ the tt225 injectors..
    Veteran Member Three Rings kwik_shift's Avatar
    Aug 28 2008
    2020 SQ5
    Lake County, IL
    I heard the same about the 02 model having idling issues. Even though the Siemens are 380cc and the TT's are 386cc. I still haven't had any issues on my 04. Let us know how it goes.
