Results 1 to 6 of 6
    Senior Member Two Rings Joeski's Avatar
    Apr 28 2008
    2013 s4, 2006 jeep commander, 2005 usp sold , 2001.5 S4 6spd rip :(
    jersey
    wheel bearing question
    hey guys quick question so i started getting a humming sound from my rear passenger side wheel found out its the bearing going. went to order one online but found that they sell jus the bearing and one that comes as a kit with a bolt, what is the best to order?
    Jan 29 2007
    08 S4 00 S4
    MD
    Re: wheel bearing question
    Quote Originally Posted by Joeski View Post
    People have reused that bolt, but it is a stretch bolt. I'd just get the "kit" with the bolt. Are you doing the install yourself?
    08 S4- Stock SOLD
    Veteran Member Three Rings 2k1audiS4's Avatar
    Oct 30 2007
    Pasadena, MD
    Get the bolt with it. I beleive you need a press for the install though.
    2001.5 S4 Silver 6MT......GIAC X, APR Bi-Pipe, FMIC, "Custom" UUC VM1, RS4 Clutch, APR R1 DV's, AWE DTS, K&N, Eibach pro kit, D3........SOLD
    2000 S4 Black 6MT.....Stock........SOLD
    2000 A6 2.7T 6MT.....Stock..... SOLD
    2001 S4 Sport Black 6MT.....Stock......SOLD
    2001.5 S4 Santorin 6MT....Stg2.....SOLD
    2001.5 S4 Sport Santorin 6MT....Stg2....SOLD
    2001 S4 Sport Silver 6MT.....Stg1....ACCIDENT THEN SOLD
    Established Member Two Rings rick_chicago's Avatar
    Apr 29 2008
    B5 S4 (Stg 2), Honda CR-V
    Chicago (NW)
    Link to Rear Bearing DIY
    Have fun...mine was seized in the hub like a mo-fo. Shop had to air hammer the thing to death to get it out.
    Stg 2 B5 S4
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    The bearing does need to be pressed out and new bearing pressed in.
    It probably is best to get new bolt with bearing. I have changed rear bearings 4 different times. My old A4, a buddies S4 and both of my rear bearings on my S4. I reused my bolts but I didnt realize it was better to get new bolt. Oh well. Hopefully they will last.
    It is relatively easy to replace. Just need the right tools. There is a writeup on audiworld I think. With pics best thing to keep in mind is take the center bolt out with car on the ground. Much easier to do.
    What I did was took the hub assembly off then took that to Napa or anyplace that has a machine shop with press and had them press it out and back in.
    Last time I did it a month ago cost me just under 100 bucks for bearing and to have the shop press old bearing out and back in.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
    Veteran Member Three Rings OldYella's Avatar
    Aug 18 2007
    Ohio
    If you have the space Harbor Freight has press's for under $100... Could be useful for the other side.
    2002 TT Silver 225
    2001.5 S4 Imola 6M (Sold)
