Results 1 to 11 of 11
    Active Member Four Rings EUROTEK//S4's Avatar
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    What is needed to install Pionner AVIC-F90BT in a 01' B5 S4 ?
    What is needed to install Pionner AVIC-F90BT in a 01' B5 S4 ? and how many hours would it usually take ? labor ?
    01' B5 S4 STG.II TIP
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Re: What is needed to install Pionner AVIC-F90BT in a 01' B5 S4 ?
    AVIC-F00BT $623 .vs. F90BT $920
    Sep 13 2008
    Western Chicago Burbs
    there have been so many threads like this lately. go to www.crutchfield.com and go to outfit my car and it will show you all of the stuff you need. Good choice on the f90bt. just got one for myself but im getting it installed at either ABT or Rays Electronics.
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    install is very simple...use search there is a diy for the avic d3 and its the same thing except for the bluetooth part...and use avic411.com to learn how to bypass....the hardest part is wiring everything which i would recommend doing at home before you start on the car....then pop out the old radio, plug in the harnesses, run ur mic and pop in the navi....didn't take me and my cousin who is good with radio's and installing systems more than 2 hours
    .....good luck
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    Im prolly gonna have ABT install it....or
    http://www.showtimeaudio.net/
    Im just looking to see where I can get the best price on it....ebay has them ~ $600-700
    but I heard if you buy the AVIC from a non-authorized pioneer dealer it not covered under warranty ?
    Senior Member Three Rings diaftia's Avatar
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by EUROTEK//S4 View Post
    I just got mine from a local wholesaler for $575 out the door.
    I have seen the 90's on Amazon for $535 too.
    03' RS6 - Mugello Blue, Ebony Interior. 19" V710's
    Sold - 2006 6SP Silver B7 S4 - APR Exhaust, piggies, JHM Tuned, VMR V708's
    Sold - 01.5 B5 S4 6-Speed - Neuspeed Exhaust, GIAC-X ECU, Short Shifter, 034 Diverter valves and TBB, VMR V708's
    Oct 19 2007
    Danville, CA
    You need a harness, powered antenna adaptor Metra Kit (9105) and several hours labor if you are doing the Sirius stuff too. If you are not doing sirius and connecting it to the basic speakers with no amps most of the work is done outside the car (pre-wiring) and depending on your proficiency can be done relatively quickly. Most of the work (and subsequently time) is running wires.
    FYI I used the little metallic sticky pad that came with the GPS antenna and put it under the Satellite antenna in the rear deck instead (using one side of velcro). VASTLY improved my satellite reception. Just put the GPS antenna in the far passenger side of the windshield and it works just fine.
    Since the F series runs WinCE there is a SLEW of things that you can tweak on these things. Check www.avic411.com. I cheated and am running the "Maverick's mods" and they are working great since he had most of what I wanted.
    Feb 02 2007
    BMW M3/AUDI S4
    Chicago,IL
    ^^ thanks!! does your local wholesaler have a website ?
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Do this yourself, there is no point in paying an installer a couple hundred dollars to do this. If you get the metra dash kit, metra wiring harness for the b5, and the antenna adapter (which you will need to buy anyway) you can do this install in under an hour. The metra wiring harness is color coded exactly the same as the pioneer HU so you just match the wire colors and plug in the 2 harnesses. There are plenty of write-ups on here that walk you through the bypass too.
    Oct 19 2007
    Danville, CA
    Nah, been there for years but the name of it is Guru Electronics in San Jose, CA.
    There are some cheap ones out there. Look on Amazon and Ebay.
    I think this one is a 900bt but I am not sure. But its only $599.
    Oct 19 2007
    Danville, CA
    I started a facebook group for AVIC users. Come join if you get an AVIC and are on FB.
    http://www.facebook.com/group.php?gid=42760514227
