Need some input on this, I replaced the belt and tensioner and when I was adjusting the tensioner I put in an 8mm allen key between the tensioner roller and tensioner, then I turned the eccentric adjuster to where it was pointing before and locked it up.
Problem is after the car ran for a couple of minutes the space went down to about 3mm.
So I used the 8mm spacer again, then backed off the eccentric adjuster and retightened. After a couple of minutes of idling the tensioner stayed where it was. I just went for a 20 minute drive came back and the space has shrunken down to 6-6.5mm. Is this ok now?
