Results 1 to 8 of 8
    Jan 05 2009
    los angeles
    smog check message "cannot communicate with car"
    i went to smog my 1998 a4 and that came back, when pluging the car in it couldnt communicate, any ideas? knowledge or what part is bad thanks
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: smog check message "cannot communicate with car"
    check the diagnostic fuse. it should be one of the micro/mini fuses and i believe it is 5 or 10 amp. fuse position 5 iirc. refer to the cover to be certain. i have seen a few tester cables get shorted out and pop that fuse causing no communication.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Jan 05 2009
    los angeles
    thanks man ill give that a shot, and repost
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    if thats fine, then check the fuse in the back of the radio, that blows and you cant access the obd port
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Jan 05 2009
    los angeles
    well that fuse is fine, along with the others, any other ideas?
    Jan 05 2009
    los angeles
    so i found out that if you have an aftermarket stereo in older audis it cannot communicate with the smog machine and you are exempt from that part haha
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    exempt eh? from readiness codes and cels? explain more, i would assume they would make you fix it before they passed you.
    Veteran Member Four Rings Kyle H's Avatar
    Sep 21 2006
    98 A4 1.8tQM
    San Diego, CA
    Is your abs/brake light on?
    If your module is bad it wont let you communicate.... you just need to unplug it if so.
    "Einstein: Any man who can drive safely while kissing a pretty girl
    is simply not giving the kiss the attention it deserves. "
    because racecar.
