Results 1 to 14 of 14
    Veteran Member Three Rings djsnowman777's Avatar
    Apr 22 2008
    Queens NYC
    awe boost buage install help!!!!!!!!
    i got my awe boost guage today so i had some time i figured i try installing it myself.....went step by step got everything working until i get to the ecu bolt number 5 under the driver wiper side ....i couldnt get in there to get it out . i started at 2 gave up at 7 .....im gonna shot myself. is there another way of installing it .....anybody have a write up ....everything at diy is nosence need something better help me
    Account Terminated Two Rings
    Oct 09 2008
    moroblue 04 s4 6sp
    brooklyn
    Re: awe boost buage install help!!!!!!!!
    yes when i installed mine i didn't go the ecu way you have to take off
    the left tire and you will see a small gromet go inside the car and take off the
    bottom piece where the ob2 port is you will see threres 2 scews on the bottom and 2 on the side where the fuse box is then just pull it and she will come out then just route the wire out and use zip ties follow the brake lines inside the tire well and make sure you don't tie your zip ties to tight done
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Did you take the plastic cowling off? You have to remove both windshield wipers to do it. My passenger side seems to be welded in place, so I could only remove the drivers side wiper. That still gave me just enough play in the cowling to use a flex shaft to get that last ecu screw out.
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings 20vpower's Avatar
    Oct 05 2006
    1998 A41.8TQMS
    San Jose, CA
    or you can just break the plastic on the last screw off, its just a pita anyway
    Previously: 12vPower
    97 12v fwd CACTUS GREEN (SOLD... thank god)
    98 1.8tqms MELANGE 50 trimd
    Registered Member Three Rings VagStaR's Avatar
    Oct 03 2008
    04 A4 tqm. 99 saab 93 2.0T 5sp
    York, PA
    I really didn't have any problems at all during my install. The part that took me the longest was connecting the T, because I took off the TIP and throttle body to hide the connection under the manifold. As for the ECU cover bolts, I just use a 3/8 drive ratchet, and all was fine. You just kinda have to be a little bit rough with the cowl cover to get to it.
    May 03 2008
    Orlando
    Quote Originally Posted by 20vpower View Post
    and then wait for water to get in the ecu box and really give you a bad day
    Kevin W.
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    You could always run it through the wheel well
    http://podi.ca/Installation.aspx#part1
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Dont break anything off ! Its pretty simple ...
    1. Remove the drivers wiper arm
    2. Use a thin extension on your socket and slide it through the hole the wiper connected through and guide it into the screw in the back.
    3. back out the 5th screw till loose then remove the socket and reach in with your fingers and pull out the screw by hand.
    For re-installation just reverse the instructions and start by placing the screw in place by hand.
    I have removed 30+ ECUs this way without breaking anything.
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
    Senior Member Three Rings FourRingsB6's Avatar
    Oct 07 2008
    2005 A4(HIS), 1999 Jetta(HERS)
    Lancaster, PA
    QuattroRocket is right. I just did this a week ago. Follow the step by step on awe's site and you should have no problems. Make sure you have a short extension though or else you will hit the hood when going through the hole for the wiper.
    Stretched, poked, and slammed.
    Veteran Member Four Rings OneBadAudi's Avatar
    Feb 25 2008
    02 A4 Quattro, 09 Yami YZ250f
    Cape May, NJ
    run it through the ecu box, cut a small hole on that tubing that goes to the ecu on the motor side, run the vac line through that, i did that and it was no problem, u gotta start from the inside, makes life a lot easier to see where your running it to....also
    Buy from WINSTON....best product for the buck...
    02 A4 Quattro stage 1+ (Giac Tuned)
    Siemens 380 injectors
    APR R1 DV
    K&N Air Filter
    5% tint
    STACKS boost gauge W/ Podi Column Mount
    Lip Spoiler
    Complete JL Audio sound system
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Did you remove the plastic cover attached to the bottom of the windshield? If not just gently pull on it upwards. It will pop right out. Then you will have enough room for the last torx screws. Then, use some soapy water and pull it through the nipple on the bottom. I used Matini's DIY on www.a4mods.com when installing my Podi .
    Apr 01 2007
    1983 Chevy Silverado
    houston texas
    Quote Originally Posted by [email protected] View Post
    thank god you said that! all yall are working way to hard. i installed my gauge in less than 15 minutes. just turn the wheel poke the hose through, turn the wheel the other way, poke it through and your done!
    barrett
    2019 SQ5 Prestige
    Apr 22 2008
    Queens NYC
    okie guys i installed it .....unfortuntly i had no paitience and snap the back piece off ...wasent a big brake just enough to take it off so the cover is in pretty full shape . ran everything through connected the T fitting and everything is running as instructions said.....had a minor kinned problem with the house under the inside dash but fixed it ....now my only question is when i turn on the car the guage read - 20 hg ......when i took it for a test run the psi went up to about 10 psi not to much as theres was traffic but then when i was crusing it was in the hg once more going down to 20 then up between 5psi and 20 hg ...is that normal reading or did i miss something ? i know the guage is more for looks and not performance but just want to make sure i installed it right
    Aug 24 2005
    Cali
    sounds about right if ur stock
