Results 1 to 2 of 2
    Aug 06 2008
    wayne pa
    Hub Centric Ring
    should i go for a plastic or aluminum set? what are the pros and cons if any
    Deactivated Four Rings
    Oct 06 2006
    South Bend, IN
    Re: Hub Centric Ring
    Aluminum are more durable if you are going to the track or if you will be changing wheels frequently. Plastic is better if wheel will stay on for long periods of time as aluminum may corrode and "stick" to the hubs on occasion.
