Results 1 to 6 of 6
    Senior Member Three Rings MOtown A4's Avatar
    Oct 06 2008
    2001 Audi A4 1.8 T
    Shelby Twp. MIchigan
    Exclamation HELP boost spikes boost cuts and CEL
    like the title says, threw a CEL and was messing with it a little and noticed this morning it was only allowing it to boost 5 PSI. now this afternoon on my way home it was spiking 15-16 and going back down to 13-11. any ideas?
    Oct 06 2008
    2001 Audi A4 1.8 T
    Re: HELP boost spikes boost cuts and CEL
    no one?
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    probably your N75 is going bad.
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Oct 06 2008
    2001 Audi A4 1.8 T
    Quote Originally Posted by pipe7284 View Post
    well i was messing around with that general area under the hood on friday, do you think its just a bad connection?
    this same thing seems to happen every time i get on it real good and then it disappears a day or so later.
    Sep 14 2006
    Lansing, MI
    Try to disconnect it from all the sides and make sure there is no debri on it, make sure all the hoses are free of dirt. clean up a bit the connector and put everything back together.
    SOLD
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    check for boost leaks with a pressure tester. if you have a boost/vacuum gauge, are you reading lower vacuum? i just recently fixed a boost/vacuum leak that i had. it was causing 10" Hg instead of 20 and 10psi spike and 7psi held rather than 13 spike and 10 held (stock programming). a semi loose or cracked hose may cause a leak one day, but on another day be sealed enough to achieve full boost a few times. if it seems like more of an electrical issue, run vag on it and check/log blocks 115 as well as 3 and 32.
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
