Results 1 to 11 of 11
    Veteran Member Three Rings CheesmoS4's Avatar
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Quick Response on Turbo Kit
    So i found, what i think is a pretty good deal on a AWE Turbo Kit. It k04s, smics ( no shrouds), giac software, and flashloader. Does not come with FUELING or for another 500 i can get the fueling... Is this a pretty good deal, the kit he says has a 18K on it, and he says that the turbos are in great shape? Any advice on questions i should ask him to make sure i dont get ripped off and should i get this kit?
    Veteran Member Four Rings CONTROL ONE's Avatar
    Sep 19 2008
    2014 BMW M235i 6MT, 2010 Audi S4 6MT
    Toronto, Canada
    Re: Quick Response on Turbo Kit
    Is this the one in Baltimore?
    Veteran Member Four Rings S4_NE's Avatar
    Aug 07 2008
    just my two S4's
    Fairfield County CT
    IMO if you are getting uses turbo's look at them first hand, also check fo rshaft play. If not first hand looking at them I woul dnot buy them, as for the tune and ICs I would but turbo's are a PITA in install and you don't want to put them in an dthey blow a week later. good luck
    2001 S4 TIP STG 3 EPL tune,517 trans shop, and Stuff
    1998 Jeep Grand Cherokee , beater/off road rig (pending lift WIP)
    2001 S4 Avant TIP Sold to a good home
    Turbo's are the Perfect Drug
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Quote Originally Posted by CONTROL ONE View Post
    Yes this the one in baltimore off of craigslist, have u looked at these?
    Apr 11 2008
    00 s4 90 crx
    High Point, NC
    If its really cheap then get it. K04 rebuild kits arent that expensive these days, so you might be able to get the turbo kit and rebuild the turbos while staying in your budget. This all depends on the price of the kit, though. Hell, the turbos might get to you and be fine and you not need to rebuild them...but with 18k miles it might be better to go ahead and do it while theyre out of the car. Either way, good luck on the purchase if you decide to get it!
    2000 Brilliant Black S4
    -DNA Catback, Piggies, Darintake w/ITG panel filter, 710n's, 034 TBB, 034 F hose, Vast clutch, JHM shifter & bushings, Vogtland/Koni's, Hotchkis Sways, ECS 12.5mm spacers
    2010 Honda Civic Ex Sport Auto
    -Stock daily driver/panty dropper
    2014 Fiat 500 Sport
    -Stock cone dodger for now. Suspension coming soon.
    Registered Member Two Rings
    Jan 09 2008
    2001.5 s4
    I would explain to the buyer that no one buys turbos sight unseen and you are going to send them to be rebuilt at blouch. Use that to talk him down further on the price.
    or buy everything but the turbos and buy new k04's, you'll still be out on top.
    Also mention that you posted on here and AW (and do so) and that people told you that none of us with half a brain would throw used turbos in a car that requires this much work to change.
    thats what i would do
    GL
    Active Member Four Rings
    Dec 11 2006
    Boston
    Quote Originally Posted by CheesmoS4 View Post
    I believe that is casawhites4's old setup.
    Stage 3+ RS6's
    Aug 24 2005
    Silver 01.5 Audi S4
    Northeastern OHIO
    Quote Originally Posted by deb38 View Post
    I think it is also.... i think i might get everything and hopefully the price is lowered. I was thinking the samething on the rebuild or just buying the other parts AWE SMICs and such and just going ahead and buying the new ko4s. I just wanna be stage 3 soo bad i am itching like a mo fo.
    here are the pics of the turbos he sent me
    Second one:
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    k04s for 1900 in the classifieds...buy everything else from the guy in Bodymore.
    Frimmel: i only speak when i have something negative to say.
    Grah4m: i lost to a giraffe. be careful out there.
    ThirdStrike:leave your feelings at the keyboard
    Dec 11 2006
    Boston
    For 3500 it is a bit pricey.
    I sold my used K04's for 1000. The highest I would have maybe got was 1300.
    Used SMIC are worth about 700-800
    GIAC Software about another 700
    Loader is about 100
    You do the math.
    Stage 3+ RS6's
    Veteran Member Three Rings awdbiturbo's Avatar
    Apr 20 2004
    01.5 S4 /95.5 URS6/72 914/
    Boston
    Buy them and immediately rs6 brid them!
    2001 Audi S4 Stage 3+/996TT with mods/HURACAN LP610-4 VORSTEINER NOVITEC VF ENGINEERING / 22 AUDI RSQ8 NARDO CARBON/22 RS6 NARDO BLACK OPTICS IE EVENTURI CTS
