Results 1 to 21 of 21
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    how to rig up a bracket for a FMIC?
    what are people using to mount a FMIC core? what is used and where does that attach to? the AC condenser bolts maybe?
    anyone have some pictures of their homemade brackets?
    thanks!!!
    Veteran Member Four Rings pipe7284's Avatar
    Sep 14 2006
    `07 Audi A4 S-Line 6MT Quattro | '01 Audi S4 AVANT 6spd
    Lansing, MI
    Re: how to rig up a bracket for a FMIC?
    go to Home Depot
    '01 Audi S4 6spd Black AVANT DAZ E85 Tune Frankenturbo F21s / 034 RS4 inlets / BOSCH EV4 72# injectors / Walbro 450L fuel pump / Daz 89mm maf housing / AFE Intake Cone / SRM SMICs / 034 street density trans and motor mounts / SSAC downpipes / Vibrant catback exhaust / H&R Ultra Low Coilovers / 18x9.5 Rota Grids / 17z Brembo front BBK / 034 Rear BBK / JHM Short shifter / JHM stg 3 clutch / PODI Boost gauge / [/CENTER]
    SOLD
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    X2, go to home depot and fab something up. I just used this like strip of aluminum bar
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    i used aluminum too. easy to drill, cut, and shape. painted it and then used allen head bolts to hold it together FTW!!
    had to use some rubber grommets for the backs of the bolts to keep it from grinding into the condenser.
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Jun 04 2007
    Austin/DFW, TX
    I also used Plasti dip to paint it with minimal sanding and it looks stealth
    My 5-Speed Swap DIY
    - B6 USP
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Home Depot/Lowes/Menards.
    I have dimensions if you really need 'em, but it's pretty simple.
    Veteran Member Four Rings danphines's Avatar
    Dec 23 2008
    2000 ATW 1.8TQM
    Rehoboth Beach, DE
    i didnt use any bracket i dont think you need one mine is held up by the piping.
    Unitronic stage 2, 3 inch turboback, Stasis SS coils...
    Veteran Member Three Rings festerfm's Avatar
    Feb 07 2008
    just the a4
    northeast pa
    i am actually going through this myself... got the intercooler that looks damn near identical to the first pic in this thread.... not sure how i want to mount it or what/how to do it..... do i have to pull the nose off like they do for the service mode or just the front bumper?
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Quote Originally Posted by festerfm View Post
    Just the bumper cover. That includes the aluminum support that's behind the bumper skin. It will have to be trimmed, probably both the aluminum and the bumper skin.
    Quote Originally Posted by danphines View Post
    You should use some sort of support, even if it's only bungee cords. That intercooler weighs like 15lbs, having your pipes hold it up will eventually lead to problems down the road.
    Do it right the first time and save money b/c you don't have to do it twice.
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    i used Al flat stock and made two upside down L's then used a 1/8" steel peice to make a diagonal brace on each one. it doesnt span the entire radiator, and is more than sturdy enough
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Quote Originally Posted by djwimbo View Post
    This how I made mine then painted it black very cheap and effective
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Sep 04 2008
    Columbus O-high-O
    i had a 3" core that was way too tall. i traded it fora core that is 2.75" by 7.5" tall. even with it only being 2.75" wide it still looks the rebar and alot of the bumper will have to be trimmed.
    were any of you able to still use the bumper grilles after trimming the bumper?
    Sep 28 2006
    Lexington
    Quote Originally Posted by pipe7284 View Post
    go to Home Depot
    Core upside down??
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Veteran Member Four Rings ghost6303's Avatar
    Nov 03 2008
    98A41.8TQM
    as long as it fits i dont think theres a up or down to it.
    Feb 07 2008
    just the a4
    northeast pa
    hate to bring this back from the dead.... AGAIN.... how much $$$ are you guys paying for your aluminum banding/strapping?? i went to the local hardware store today but they didnt have anything like i thought i wanted. how sturdy is the aluminum you guys are using? is it the strapping that is in the rolls or is it the stuff you get in 3 foot straight sections that is like 1/4" thick?? i didnt think there was that much difference but i found out today that there is... any specific stuff that u'r using??
    <--------yes, i used my audi to drag my deer out of the woods. it was heavy, i was cold, car had heat, much less work, and frankly, it was far. the deer was big, i am not, just seemed like the right thing to do. if it werent for the apr2+ i may not have been able to pull that monstrosity out of the woods w/out a helicoptor. i cant afford a helicoptor, i have a hard enough time affording my audi. all this being said, yes. that is an apr2+ awd audi pulling a deer out of the woods.
    Nov 03 2008
    98A41.8TQM
    not the stuff in the roll that you use to attach 2x4's together. they are sturdy metal strips probably 0.125" thick. about $8 each at home depot.
    Veteran Member Four Rings tamadrumr88's Avatar
    Nov 03 2006
    lehigh valley pa
    Made this out of 3/16" stock and bent it in a vice, then I painted it with high temp engine paint... total cost was about $8 not including the 3" cutting wheel which I also used to fab up the intercooler piping
    Jun 04 2007
    Austin/DFW, TX
    At most $10
    My 5-Speed Swap DIY
    - B6 USP
    Feb 07 2008
    just the a4
    northeast pa
    Quote Originally Posted by tamadrumr88 View Post
    where can i go to get the flat stock??
    Senior Member Two Rings beAu4's Avatar
    Nov 23 2008
    98.5 Audi A4, Ford Ranger Baja
    San Jose CA
    98 Pearl White
