Results 1 to 25 of 25
    Senior Member Three Rings diaftia's Avatar
    Oct 19 2007
    Danville, CA
    B5 Aftermarket Nav/Bluetooth users
    I just got an AVIC-F90BT and I installed it and everything is working fine except one thing. When I installed it I put the hands free mic in the OEM location removing the original mic that was up there. When I called someone they said that I sounded like I was in a tin can. Has anyone else experienced this? Is it because of the location of the mic?
    03' RS6 - Mugello Blue, Ebony Interior. 19" V710's
    Sold - 2006 6SP Silver B7 S4 - APR Exhaust, piggies, JHM Tuned, VMR V708's
    Sold - 01.5 B5 S4 6-Speed - Neuspeed Exhaust, GIAC-X ECU, Short Shifter, 034 Diverter valves and TBB, VMR V708's
    Veteran Member Three Rings TheDarkness's Avatar
    Jul 13 2008
    15' A3 2.0T , b5 S4 Stage III
    Re: B5 Aftermarket Nav/Bluetooth users
    nice, I was about to pull the trigger on a Pioneer f90bt. Mind I ask where you got yours at? How did you pay for installation or did you do it yourself?
    Can't wait to get mine!
    2001 Stage III Pearl White B5 S4: Frankenturbo F21s | Iforged Flux | Solo Motorsports Dyno Tune | Bosch EV14 52#
    2015 A3 2.0T 8V Mythos Black: KW V3s
    Veteran Member Three Rings mmxruffryder15's Avatar
    Mar 28 2008
    new york
    yea its because of the location of the mic...the mic has to be facing you...i put mine on the steering column and it works perfectly
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    Quote Originally Posted by TheDarkness View Post
    Do it yourself. My D3 took 30 minutes to install with a pair of scissors for wire strippers and an army knife for a screw driver. If you buy the right wiring harness it couldn't be any easier...white wire connects to white wire...yellow wire connects to yellow wire....etc. Obviously the ninja placement of the mic in the factory location might take a little longer but this is as easy as changing an air filter.
    Veteran Member Four Rings infinkc's Avatar
    Feb 14 2004
    S Ã C, CÃ*
    you have to take the pioneer mic apart (2 clips) and point it downwards in the factory location. works well for me.
    Veteran Member Four Rings mrpeterparker's Avatar
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    or drill a hole in the vented area there... and route the microphone vertically through it...
    that's what i did... you'll need some stuff to keep it there though.. the car install shop near you should have some thick black adhesive that you can get from them.
    i'm not sure what it's called.... sorry
    infinkc's idea will work too
    Lurker
    Oct 19 2007
    Danville, CA
    I found it on amazon for a little cheaper than I got it from a local wholesale retailer for. I think you can get them on Amazon for ~$550. I got mine for $575 including tax.
    I did the install myself but I have done several car audio installs before.
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by mrpeterparker View Post
    That is not a bad idea. RTV or similar adhesive would work... Not sure I like putting a hole in it but its still a small panel that can be replaced.
    thanks!
    Senior Member Two Rings thebigchu's Avatar
    Oct 24 2007
    2004 Yukon Denali, 2010 Ibis S4 Prestige 6M
    San Ramon, Ca.
    Pics of it installed?
    2010 Ibis White S4 6M Prestige. Stage 1 (034 Motorsport). ADS, Sports Diff, B&O, Nappa, Tech package, 19" Trispoke.
    SOLD - 2002 Brilliant Black S4 6M ** Stage 1 ** (GIAC-X * JHM "Solid" Short Shifter * 034 DVs/TBB * Avic D3 * Clear Corners)
    http://www.audizine.com/classifieds/...inside-&cat=67
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by thebigchu View Post
    I will try to get some tonight. I need to relocate the mic and see how it goes. I will get some then.
    Oct 19 2007
    Danville, CA
    here is my install:
    Left myself some voicemails at work with the mic several different ways. The best seemed to be out in the open but not by much. The happy medium seemed to be with the mic turned sideways so one slot of each side of the side holes are facing down. Cut down on the "tinnyness".
    Oct 19 2007
    Danville, CA
    I found this funny.
    For those that don't know the F-Series runs Windows CE and can be modified extensively.
    Veteran Member Four Rings AMC's Avatar
    Jun 15 2007
    '19 Spektrum Golf RS, '18 Audi TTRS
    Quote Originally Posted by diaftia View Post
    im having the same exact issue as u. my mic sounds like a wind tunnel they say. i was thinking of putting the mic cloth over it and taping the area shut so its wind proof or w/e and seeing if that works. i also placed it in the same spot
    Driver Supply
    Current
    '19 Spektrum Golf RS DAZA
    '18 Audi TTRS
    Sold
    '07 Stage 3 2.7t swapped B7 A4
    '01.5 Stage 63463 Silver S4
    '13 black Audi S7
    '03 Porsche 911T
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by AMC View Post
    Yeah there was a piece of felt that was over the OEM Mic. I didnt think about removing it and using it. Let us know how it works if you try it.
    As I stated in another post there was not all that much difference putting it out in the open. You can call yourself (I used my VM at work) and leave different messages with the mic in different positions. The happy medium for me was with the mic sideways (taking note of the spaces in the side of the mic) in the OEM spot. There was just not a significant sound improvement over having it in the OEM spot vs. in the open.
    Oct 24 2007
    San Ramon, Ca.
    here is my install:
    Looks good man!
    Is that SD card Nogaro Blue?
    Oct 19 2007
    Danville, CA
    Looks good man!
    Of course! Nothing but the finest. You got to coordinate!
    Oct 19 2007
    Danville, CA
    I started a facebook group for AVIC users. Come join if you are on FB.
    http://www.facebook.com/group.php?gid=42760514227
    Senior Member Three Rings NorCalS4's Avatar
    Mar 16 2009
    Chico, Ca
    hey bringing this back. Gettin a f90bt in a day or two. Was wondering if anyone has spliced the OEM mic and made it work withe this HU?
    Just was thinking the OEM mic might be better then the mic included with the unit and if it can easily be spliced into, it could make an easier install.
    '01.5 Silver S4 6spd
    ~V1 hardwired
    ~AWE Boost gauge in DIY vent pod
    ~ASP DTS
    ~F90BT w/ JL 250/1 & W3 12"
    Oct 19 2007
    Danville, CA
    I don't recall why but I do remember it not being able to work. I installed mine in the original location but did it downward (vertically) through the vent (cutting away some of the vent) and used RTV to make it stay. Some people have had fine quality with it laying in the vent horizontally but I did not. People could not hear that well or they said I sounded like I was in a box.
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    i did the same and it wasn't "good" enough.. so i recently relocated it out next to my V1
    i'm still not convinced it's any better...
    i think it's just a crappy mic one way or another..
    Lurker
    Mar 16 2009
    Chico, Ca
    So should I just foreget it?? I mean i dont even care all that much if I have bluetooth in the car and I deff. dont wanna go though running the cord and installing the mic if it not gonna sound good.
    ~V1 hardwired
    ~ASP DTS
    Oct 17 2007
    01 Silver B5S4
    minneapolis, mn
    Quote Originally Posted by NorCalS4 View Post
    uh no.... you already own the hardware.. install it.. you may have better results then us...
    i still use mine everyday... i could care less how bad i sound as long as people can still understand me.
    also, isn't it illegal in Cali to drive on the phone w/o a handsfree kit?
    do it.
    Lurker
    Mar 16 2009
    Chico, Ca
    do it.
    Word. I guess ill install.
    yes, in cali you have to use handsfree, but your also not suppose to mod your car lol.
    Anyways, maybe this is eh answer, as i believe he is an experienced installer
    Quote Originally Posted by infinkc View Post
    ~V1 hardwired
    ~ASP DTS
    Senior Member One Ring dcarlson01's Avatar
    Jan 30 2008
    upstste ny
    how did you get yours to fit in so perfectly? on mine which is same setup u have, the bottom left corner of the dash kit will not go in. It will fit by itsels, and the radio fits with more room if needed but when they are mounted to eachother(dash kit and f90bt) it won't fit perfectly. did you have a problem like this? if so what was the fix?
    Oct 19 2007
    Danville, CA
    Quote Originally Posted by dcarlson01 View Post
    Mine fit perfectly on that aspect. All I can suggest is that you make sure the wires are not jamming up behind the radio and it's back all the way. As long as your kit looks the same as mine it will fit.
