Results 1 to 4 of 4
    Established Member Two Rings andrewbb89's Avatar
    Aug 21 2008
    cruise control not working
    my cruise control hasnt worked since i bought the car. its a manual so i always thought there was no cruise feature. but it has the cruise lever. i have checked the fuse box and couldnt find one that was blown out. it seems there is no power to the module at all. im going to vag it shortly to see if anything comes up. any idea on what i should do?
    Established Member Two Rings Torqie's Avatar
    Jul 15 2007
    2003 A4 quattro 5 speed
    Salt Lake City, Utah
    Re: cruise control not working
    Quote Originally Posted by andrewbb89 View Post
    this happened to me... make sure your brake light isnt staying on / even coming on... it could be the brake sensor switch behind the brake pedal getting stuck... quick easy fix, and the part is cheap. It is a known problem.
    Established Member Two Rings Uncle Sal's Avatar
    Apr 25 2007
    New York
    Same problem hear. Ever since I bought my car to the dealer it stopped working. I've used the Cruise Control on long trips, but now nothing works. My brake lights are not staying on when releasing the pedal so can it still be the sensor even though the brake light goes off as it should?
    Any help appreciated. Thanks
    02' 18T Quattro 5 speed / Cold weather pkg / Rs4 Sway bars / Koni FSD- Eibach Pro combo / B6 S4 18's...... Timing belt done, new ECU.
    Jul 15 2007
    Mine didnt always stay on when it happened... but soon it started everytime. It may not be it, but I know if the sensor is bad the cruise control thinks your brake is always on... therefor not kicking on.
