Results 1 to 10 of 10
    Sep 12 2008
    South Central PA
    Door Panel Removal?
    alright, well my friend decided that she needed to slam my passenger side rear door. i heard a funny twang noise and a pop. so naturally i looked. everything seemed fine. so i rolled down the window. went down. sweet. wouldnt go back up. i was furious.
    but i can push the window up and down effortlessly with my hand and im hoping that it is just knocked off track.
    i tried taking the door panel off but i cannot for the life of me figure it out.
    if anyone can help it would very awesome
    thanks in advance!
    EFR | 7163
    268/260 cams
    I.E. Intake Manifold / 70mm
    BoostManager+
    Meth Head
    Veteran Member Four Rings kwimberly's Avatar
    May 03 2008
    Orlando
    Kevin W.
    2003 A4 1.8T quattro 5-spd. | USP lower | APR ECU w/ TT225's | APR TIP | test pipe | FMIC | Apikol snub | ecodes | Podi® | AWE sport pedals | JHM SSK/linkage | Forge 007 DV | '02 OEM sport suspension | OEM sport wheels | B6 S4 brakes w/ TyrolSport stiffeners | RS4 rear sway bar| Magnaflow 14829's| AVIC F700BT | hard-wired Passport 9500 | Side-mount trash bag hanging from shifter
    Veteran Member Four Rings lookaught's Avatar
    Apr 20 2007
    2002 1.8t Avant GTRS, Aprilia SXV 550, BMW F800GS, Ram EcoDiesel, 1990 Bronco
    Lander, Wyoming
    Re: Door Panel Removal?
    FYI that bottom screw that is black was a HUGE PITA to remove on my car. It goes through into where the elements can rust it a bit. Be careful and use a good #2 screwdriver when you remove that or it can strip. I didn't even put it back in. In retrospect I should have used a power drill with a screwdriver bit to put extra force into the screw to keep it from camming out.
    I also broke a few clips on a rear door, but didnt replace them and have no rattles or problems for the past few months.
    Jon
    go > show
    Ich liebe mein Audi
    2002 GTRS Avant - Built with love, sweat, bloody knuckles, and pride.
    Sep 12 2008
    South Central PA
    thanks guys.
    i had checked the a4mods.com one. the rear is entirely different from my experience with it lol. i'm on a4mods.com all the time.
    i have the trim piece removed and all the screws that i can find.
    eh, we'll see how it goes.
    thanks again
    EFR | 7163
    268/260 cams
    BoostManager+
    Meth Head
    Apr 07 2011
    I know this thread is extremely old but it's the first thread that came up on a google search. I want to make sure this hint is there for the next person that has to deal with this. The key to removing the door panel is to remove all of the screws and then start popping the clips out from the bottom and work your way around the sides. After you've undone all of the clips you just have to lift up on the door panel and it will come off.
    Jun 27 2011
    That's a quality necrobump if I've ever seen one
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Veteran Member Three Rings 0396's Avatar
    Feb 10 2005
    L A
    My mirror switch is acting up...only works on passenger side....
    This tread is just what I was search for
    Thanks all
    0396
    Aug 27 2013
    Philly
    Quote Originally Posted by 0396 View Post
    Thanks all
    What's your plan to fix this? My switch only works the drivers side
    Veteran Member Four Rings Siggiepop's Avatar
    Aug 20 2007
    B6 A4 . Bus Pass
    Ontario, Canada
    Followed a4mods tutorial. Real easy.
    CT4952
    Feb 10 2005
    L A
    Thanks guys...what I'd funny is I found the above tread via Google vs the search function on this site. Today, I'm going to call my local dealer and order the switch.
    Enjoy your week
    0396
