Results 1 to 3 of 3
    Feb 19 2007
    2001 BMW 540i M-sport
    Charleston, SC
    Problem with horn....remains active for like 3 seconds
    Since I am changing from beige interior to black I had to remove the airbag and steering wheel.
    Anyways, I had the battery disconnected for like 3 days while I dealt with the steering wheel and airbag. In the process I decided to "realign" the airbag tabs located on the actual steering wheel, so that the airbag sits more evenly (ever since I bought the car the airbag was EVER SO SLIGHTLY misaligned) Everything went smooth....
    But, now when I go to beep the horn:
    If I press the left side of the airbag, horn beeps, everything is OK
    If I press the right side of the airbag, horn beeps, everything is OK
    But if I press the middle of the bag (activating both left and right sides), the horn beeps for about 3 seconds AFTER I release the horn.
    What could be going on?
    One thing that happened during install, I moved the clock spring and it clicked to the right, so i had to realign the steering column so that I could get my marks to line up with the clock spring dowels.....could this have damaged the clock spring any?
    Thanks guys
    -Sami-
    Feb 19 2007
    Charleston, SC
    Re: Problem with horn....remains active for like 3 seconds
    These are the codes I threw this morning:
    18107 - Powertrain Data Bus: Missing Message from Steering Wheel Electronics
    P1699 - 008 - Implausible Signal - Intermittent
    17978 - Cruise control switch Incorrect signal
    Along with some other random codes.....
    -Sami-
    Aug 26 2005
    The clock spring assembly, plugis into the Steering Columb Control Module, directly. There is no way to repostiion the two parts in relation to each other. From the DTCs you posted, it's likely that the electrical connections are not inserted properly due to misfit of the parts. Make sure the parts are assembled properly, appearance is secondary.
