Results 1 to 7 of 7
    Senior Member Two Rings mtxsho93's Avatar
    Sep 20 2008
    93 SHO, 02 A6 2.7T 6MT
    South Jersey
    alarm not arming
    I just noticed tonight that when I lock my doors using the fob that the horn does not honk and the red blinking light on the door panel no longer blinks. I recently reset my service warning light in the dash after an oil change. Did I somehow disable the alarm too? Does anyone know how to fix this?
    Ian
    Registered User Four Rings winston@podi.ca's Avatar
    Jun 11 2005
    Pods, gauges and more pods
    Vancouver, BC
    Re: alarm not arming
    Can you manually lock the driver side door which then activates the alarm?
    Sep 20 2008
    South Jersey
    Quote Originally Posted by [email protected] View Post
    The fob will lock all of the doors. I tried using the door lock button on the driver's side door panel and all of the doors locked except for the driver's side. The button went down halfway and I could not press it down any further. I closed the door and was still able to open it (i.e. it was not locked). I was still able to use the fob to lock the doors.
    This doesn't seem to have anything to do with the motion sensor. I disabled and enabled it but the situation still exists.
    Ian
    Sep 20 2008
    South Jersey
    Ok, from doing some reading online, I think that the alarm is in a valet or service mode. I will dig out the owner's manual to find a reference to this and how to reset it. I suspect that I somehow put it in this mode when I reset the oil change warning.
    Ian
    Veteran Member Four Rings Stampy's Avatar
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    OEM alarm doesn't have valet. Its not arming cause something is not right. Door isn't closed all the way, Trunk is not closed, something like that. If all those check out then its probably a bad sensor somewhere. If you have VAGcom, you should scan it. If you could lock everything from the drivers side door and it doesn't arm then something is wrong.
    Village Idiot!!!
    (\__/)
    (")_(")
    lots of rings in my garage
    Sep 20 2008
    South Jersey
    Wow, I feel stupid. I looked in the owner's manual and the Bentley last night and didn't figure anything out. I decided that a door or the trunk was probably open. I checked this morning before I left for work and the trunk was popped. The alarm arms properly.
    I did notice that the driver's door does not lock if I lock it using the door lock button on the door panel with the driver's door open. Is this normal?
    Ian
    Oct 02 2007
    A6, A8, X5, etc
    Windy City
    Good to hear it was something simple. And yeah, that prevents you from locking yourself out.
    Village Idiot!!!
    (\__/)
    (")_(")
