Results 1 to 7 of 7
    Oct 08 2008
    S FL
    Locate Paint Code
    Anyone have any idea where I can find the paint code on my '09 A-5?
    Oct 08 2008
    S FL
    Re: Locate Paint Code
    Wow. 80 reads and nobody knows.
    Never did find it in the car. Got it off the Internet. Ibis white is LY9C
    Aug 31 2007
    Santo Domingo
    It would have helped if you had posted the color :p
    Apr 19 2008
    The Big D, Tejas
    I think the code is located on a sticker somewhere near the spare tire. I don't know which number is the code. But if you find something that matches what you found on the internets, then it might help confirm your find.
    Oct 08 2008
    S FL
    Thanks. That's where it is - right next to the spare tire.
    It matched what I found on the Internet. I always buy a really small amount of Dupont car paint from my local automotive paint store to touch up the inevitable rock chips.
    Thanks again.
    Senior Member Three Rings SupraBlur's Avatar
    Jul 16 2008
    Los Angeles, CA
    Quote Originally Posted by km997s View Post
    Thanks again.
    Does the paint not have a shelf life?
    2021 Audi SQ8 - S Sport - Dragon Orange
    Previous Audis:
    2018 Audi SQ5, 2009 Audi S5
    Oct 08 2008
    S FL
    Not really sure about the shelf life. I did get a small chip on the lower front and needed the paint right away to clean it up. I put a little clear over it as well.
    After reading your question, I went into the garage and checked on a can I bought in the fall of 2004 for a BMW. The can had been used a little to spray a mirror so it had been open, but the paint looks fine. Only painting with it can confirm if it's OK, but my guess is it's OK.
    It's not expensive at $28 per half pint. That's the minimum they'll mix. I've never had a car outlast the small supply of paint.
