Results 1 to 4 of 4
    Veteran Member Three Rings A4Triple Blk's Avatar
    Jun 10 2008
    Past - 2004 A4 1.8T Quattro 6 Spd
    LI
    exhaust bracket ?
    Whats up guys a couple days ago i heard a wierd noise come from underneath my car and it turns out that it was the exhaust bracket right before the space for the spare tire at the end of the car. the bracket has cracked and it rubs against the pipe itself and makes an annoying noise so today i unscrewed that bracket from the other side and now the noise is gone thank god. but i wanna know if this will have any other effects, the exhaust is supported by the rubber hanger pieces and other things also but will this loosen the pipe up at all or anything ? thanks guys
    B8 2011 A4 Premium+ 6 speed
    Used to B6 it
    Veteran Member Four Rings A4SoftWalker's Avatar
    May 13 2008
    Avant 03A4 1.8TQMS, 05V70R, BMW535i
    NoCal - EBay
    Re: exhaust bracket ?
    So lemmie try and get this straight... the rear half of ur exhaust is only supported by the hanger on one side of the car??? U have 3 choices:
    1) Either prepare for the whole thing to fall off the car.
    2) Or go here genuinevwaudiparts.com and order the part - prepare to drive gently meanwhile.
    3) Or call up the dealer and order the part - also drive very gently meanwhile.
    Personally I will park the car till I got the part or if driving watch out for bumps.
    If u were local I would have let u have my 5yr old ones I swapped out when I did my exhaust upgrade but we are on opposite coasts.
    'SOFTWALKER MODS
    Do U have a Bentley/Dealer Manual & Tools to work on UR car properly?
    Hit-or-miss expecting manna to fall from AZ?
    Personal Motto>Walk Softly Carry a Big Stick. YEAH I'M BACK!
    BUILD? Click & be Amazed!
    Avant>Sedan! Click
    Jun 10 2008
    LI
    its the part thats welded on to the exhaust pipe how would you swap that ?
    Used to B6 it
    Veteran Member Four Rings Molotov's Avatar
    Feb 24 2007
    2005 USP 1.8TQM Avant
    Burlington, Vermont
    have somebody weld it back up?
    - Scott
    Das Build Thread
    Performance parts for sale:
    MagnaFlow Race Muffler - Vibrant 4" Filter - MAF 4" Housing
