Results 1 to 10 of 10
Thread: turning help??
    Senior Member Two Rings Trotter715's Avatar
    Apr 05 2008
    New Jersey
    Question turning help??
    lets roll. problem number 1451340598, but still havin fun. when i make turns such as into a parking space, i get a bad rubbing sound/feel coming from the wheels, primarily the left one. the tighter the turn the worse the sound/feel. i know my alignment is definitely off and i plan on getting that done this week when my new wheels come in. does anyone know what this rubbing could be? is it related to the alignment? mind you i got my upper control arms and tie rods replaced within the past 6 months.
    I'm a dog chasing cars, I wouldnt know what to do with one if I caught it.
    Apr 05 2008
    New Jersey
    Re: turning help??
    Nooooooo one knows? Not even a guess kids? thats never a good thing
    Veteran Member Four Rings 99blueb5's Avatar
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: turning help??
    are u rubbing on the plastic fender liner? get a light and see it there is any scratches or rubbing marks
    99 A4 1.8TQM:
    APR Stage 3 GT28rs kit, CM FX400 6puck, 3" downpipe, Nuespeed catback,Nuespeed short shift, Cxracing fmic, Forge007 DV, H&R coilovers, APR snub mount, gasket ported head, VDO guages, e codes, 6k's, Fiberimages CF hood/trunk, A8 BBK, IE Rods
    00 B5 S4
    Vast stage 3, Rs4 airbox, ko4's,borla cat back, neuspeed sways, statis coils, jhm fmic, SSAC Dp's
    Apr 05 2008
    New Jersey
    Re: turning help??
    nothing noticeable there. no scratches or marks.
    Jul 03 2008
    A4
    Re: turning help??
    is it clicking at all? busted CV?
    Apr 05 2008
    New Jersey
    Re: turning help??
    what do you mean by clicking? cause on a really slow/tight turn it'll buck/knock a little bit.
    Mar 10 2008
    01 S4, 99 A4
    Bellevue, WA
    Re: turning help??
    even slow 3-5mph u should hear a constant click-click click pretty fast pace if cv joints are out is it just turning left or right? check for torn CV boots
    99 A4 1.8TQM:
    00 B5 S4
    Veteran Member Four Rings Beemer832's Avatar
    Sep 21 2004
    98.5 a4 1.8tqms
    KC MO
    Re: turning help??
    sounds like CV joints to me. if not that then it has to be rubbing on the wheel liner or fender somewhere. nothing else could be rubbing.
    you should feel the CV joints clicking in the steering wheel, its pretty noticeable.
    kinda sounds like playing cards in a bicycle wheel... no im not old enough to have ever done that but i like the analogy :)
    -josh
    -josh
    98 AEB 1.8t Laser Red
    EFR 6758 with VEMS standalone in the works.
    Feb 15 2008
    E46 323i 5-Sp
    616/MI
    Re: turning help??
    If your alignment is off it's possible that you have a bent lower control arm. I've seen it a couple times where the wheels actually contacts the control arm when at full lock.
    It's worth a look.
    Apr 05 2008
    New Jersey
    Re: turning help??
    none of this sounds like its gonna be good. thanks for the help guys
