    Veteran Member Four Rings jamestown478's Avatar
    Dec 24 2008
    2000 S4 stage 2+ on meth
    Milwaukee
    econ button on climate control
    so what does the econ button on the climate control panel do exactly? I was reading in my manual and it was talking about fuel economy and some fans but am still confused on it a bit. Does it really even give u better fuel economy and if so what am I sacrificing by turning the button on?
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    Re: econ button on climate control
    The Econ button is lit when the compressor is not switched on. Hence the economy
    http://www.airconcars.com/html/how_it_works.html
    How AC works
    B5 S4 AWE Stage 3 - sold
    Dec 24 2008
    Milwaukee
    so if I have the econ button turned on will my ac not work or not work as well? so will turning that on during the winter even do anything then?
    Established Member Two Rings Brian@AR's Avatar
    Jan 28 2007
    Portland, OR
    Quote Originally Posted by jamestown478 View Post
    yes, if you turn on the econ then you are turning off the ac compressor. during the winter, if you start to fog up then you will want to turn the econ off which will turn the ac on and that will help take the moisture out of the air. thats it.
    Veteran Member Four Rings gointoscott's Avatar
    Jan 26 2006
    2001 Audi S4
    Milwaukee, WI
    Yes the Econ button shuts the A/C compressor off.
    If the temperature drops below a certain temperature (I think its 40 degrees F) the A/C compressor will not kick in at all either way with Econ Button on or off.
    Original K03's, Ecodes, H&R Coilovers, Inmotion Chip/MBC, Piggies
