Results 1 to 4 of 4
    Registered Member Two Rings
    Dec 15 2008
    NoVa
    How much does it cost to get a cat back installed and where should I do it?
    How much should it roughly cost and where should I go to have it installed? Can I just go to a random midas in my area or something? I don't know of any audi performance shops in my area.
    Re: How much does it cost to get a cat back installed and where should I do it?
    Quote Originally Posted by xzone909 View Post
    If you have the proper tools grab a friend and DIY. Very easy only takes about an hour.
    If this isnt an option, pretty much any mechanic should be able to do the job. It should run around $150 to install
    Senior Member Four Rings ...Mark...'s Avatar
    Oct 03 2008
    Murdered out 04 S4..
    Atlanta BITCHES!!!
    Free and your driveway..
    If you are really that mechanically inept, any muffler/exhaust shop will do it for you for probably whatever they charge for an hour worth of labor. $150 seems a little rediculous to me unless you are having welding done and with a bolt on catback, that should not be the case. It should be more like $50-$80.
    Veteran Member Four Rings FastB7S4's Avatar
    Mar 01 2008
    12 CC Lux Ltd, 11 Touareg, Mk3.5 Cabrio
    ChesCo, Lancaster, PA
    You'll probably be charged 1 hour of labor (price varies shop to shop) and yes any muffler shop should be able to do it for you.
    /S4
    AWE l Koni l H&R l Hotchkis l VMR l LEDs by fly
