Results 1 to 7 of 7
Thread: ECU Swap
    Veteran Member Four Rings gq9's Avatar
    Nov 07 2006
    02 A4 1.8t
    New York
    ECU Swap
    Would an ECU swap have to be done at the dealer ?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: ECU Swap
    If it has a flash on it, you can have an immobiler defeat on it, otherwise the dealer. Probably about $100.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Nov 07 2006
    02 A4 1.8t
    New York
    Re: ECU Swap
    So if I look to swap my REVO flashed ECU for stock, I would have the problem with the stock ECU, not the person getting the flashed one. Or did I understand that wrong? Thanks for response.
    Mar 21 2006
    Lakeland, FL.
    Re: ECU Swap
    No matter what you do to your ECU it'll still work in you car, as for another ECU it'll have to be programmed.
    I'm back bitches!
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: ECU Swap
    Quote Originally Posted by gq9 View Post
    You would have to get the stock ECU recoded at the dealership to retain the immobilizer III features (highly suggested). And for the flashed ECU, either the buyer will need to get the immobilizer deafeat file or get the ECU recoded at the dealer.
    Mar 21 2006
    Lakeland, FL.
    Re: ECU Swap
    The buyer of the flashed ECU couldn't have the defeat done, the original purchaser of the flash would. The dealer would be the easiest option.
    I'm back bitches!
    Jan 07 2008
    04 A4 1.8tqm
    Montreal, Canada
    Re: ECU Swap
    Quote Originally Posted by dirtybrd View Post
    Ahhh that's right! Good catch. OP I sent my APR stage 1+ flashed ECU to APR to get the Immobilzer defeat for $150 before selling it to someone. And got my spare stock ECU recoded at the dealer.
