    Veteran Member Three Rings b5andm3's Avatar
    Aug 22 2008
    Central Maryland
    tricks for muffler hangers?
    I am having a HELL of a time getting the muffer back into said hangers. This is the only thing in my way of completing my TP/DP install.
    FWIW I am putting the stock modified muffler back on.
    2000.5 A4Q - 2871r / 1.9L Stroked / IE Rods / JE Pistons / 3.5" TBE Exhaust / Forge MBC / 630cc Injectors / Walbro 255lph Fuel Pump / VR6 MAF / Unitronic Tune / CM FX600 / ECS N75 Race Valve / ECS 9lb Alum Flywheel / Forge TIP / Forge DV / ARP Head Studs / BBS LMs / RS4 Front Bumper / Hagus Mirrors / Brembo BBK / RS4 Shift Knob / JL Audio Speakers, Subwoofer & Amplifier / Clarion NX409 / HR Race Springs / Evolution Racewerks FMIC
    Veteran Member Four Rings B5A4Kevin's Avatar
    Apr 06 2008
    Brandon, FL
    Re: tricks for muffler hangers?
    if you are talking about sliding the metal rod back into the rubber hanger, silicone spray or wd-40 is best to convince the rubber into cooperating, however if that isnt readily available, any kind of lubricant should help (pam, clean motor oil, butter, whatever).
    Current whip:
    99.5 A4 1.8T quattro Sport.
    RIP:
    Brilliant Black 06 A3 2.0T 6-spd
    Brilliant Black 01 A4 1.8T QMS
    Pearl White 99 A4 1.8t QMS
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    Carb cleaner is also extremely slippery when first sprayed on, and then it evaporates. Good trick for installing hoses and stuff you don't necessarily want to slide off later.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Apr 22 2007
    Riverbank, Ca
    Make a mental note to just unbolt them next time... takes 5 minutes... I've removed mine a dozen times.. really easy to just unbolt and bolt back up.
    97 A4 2.0TQM
    Rochester, NY
    you can unbolt them, stick them on the exhaust, then bolt em back on.
