Results 1 to 4 of 4
    Jun 12 2005
    Athens Greece
    DTC 17881 "Leak Detection Pump Circuit: open circuit"
    Does any1 know how can I get rid of this CEL?
    The US spec ECU is looking for LDP while my EU spec car doesn't have the hardware and the wiring.
    Is there a way to fool the ECU with some resistor?What would be the ECU pins and the harness for the LDP?Any other ideea?
    TIA!
    Jun 12 2005
    Athens Greece
    Re: DTC 17881 "Leak Detection Pump Circuit: open circuit"
    Anyone please?!
    Dec 04 2007
    New York, NY
    good luck with that. Looks like these EVAP codes is something a lot of people here arent knowledgable in.
    try audiforums and utilize the search key as thats going to become your friend until you resolve this.
    Jun 12 2005
    Athens Greece
    I was thinking if there is a way either recoding the ECU softcode (in which case I would eventually need a login code) or hardwiring a resistor to the appropriate pins of the ECU (like clamping).
    Anybody to shed some light?
    I will post in AW too.
