Results 1 to 11 of 11
    Veteran Member Three Rings barkerd427's Avatar
    Oct 04 2006
    2007 Audi A4 & a honda
    Princeton, NC
    was wondering about hub-centric rings
    I just got some konigs for my racing setup and they fit very loosely. This is only my second set of aftermarket wheels so I am not sure how they should fit. They are obviously tight once the lugs are on, but I just wanna make sure that they will be safe. Do I need hub-centric rings for these wheels so they fit snugly to the hub? I don't want the lugs to break while I am racing and have the wheel fall off. Any expert advice would be great. I hear that I need the rings, but have no idea where I would get them.
    2007 A4 2.0T S-Line Quattro / Deep Sea Blue / Black Leather Interior / Nav / Heated front seats / Xenon head lamps / APR Snub Mount / RS4 Pedal Set / RS4 brushed aluminum grille / RS4 rear sway bar / RS4 parking brake handle / Xenon match interior lighting / SOON Custom fog light grilles with S6 LEDs and RS4 mesh and brushed aluminum trim, just need to find the trim
    Registered User Four Rings Mike@PureMS's Avatar
    Jul 19 2007
    San Diego, CA
    Re: was wondering about hub-centric rings
    The wheel should be perfectly centered on the hub without the lugs.
    If it isn't then you need hubrings.
    More localbwheel/tire shops should carry them.
    Veteran Member Three Rings road race s4's Avatar
    Jan 03 2009
    camry
    Tirerack.com has the hub centric rings also.
    Oct 04 2006
    Princeton, NC
    Thanks a lot guys. I have always bought wheels from a company so they must have had them set up for my car before I got them. I am ordering the rings now. Hopefully they will be the right size.
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    Here ya go: Clicky click
    Oct 04 2006
    Princeton, NC
    That's where I got them from too. Thanks for the link. I didn't see this info when I bought the rings.
    Aug 06 2008
    wayne pa
    does any one know if i should go with the plastic for aluminum rings ?
    Jan 03 2009
    camry
    Aluminum rings. The plastic ones will deteriorate faster.
    Jul 19 2007
    San Diego, CA
    Plastic usually works just fine, and doesn't corrode and seize to the hub like the aluminum ones can.
    Either is fine, just use anti-seize with the aluminum ones.
    Jun 14 2005
    Anaheim, CA
    Quote Originally Posted by Mike@PureMS View Post
    Ditto. I use plastic ones and they work totally fine.
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Established Member Two Rings Euroluv's Avatar
    Nov 16 2006
    should of bought them here could of saved some money http://www.1010tires.com/hubrings.asp
    "when things are good, go racing. When things arent so good, go racing."
    "M3 drivers have no friends" -Jeremy Clarkson
