Results 1 to 13 of 13
    Veteran Member Three Rings Blue_S4's Avatar
    Feb 26 2008
    1968 plymouth roadrunner 440+6
    Rockford, MI
    Please help finishing diagnosing my misfires...TIA
    changed all plugs, no changes at all.
    VAG-COM log groups 014/015/016 show about 200 misfires in 20 seconds on cyl 5, and 7 on cyl 1, 0 on rest
    I then swap the coil pack of 5 with 6, and there is no change at all in misfires, so its not the coil pack.
    Then I swap ICMs and I get 252 misfires on cyl 2 and 43 on cyl 5 in about 30 seconds of idling, 0 on the rest.
    I still need to do a thorough boost leak check. but what does it sound like to you guys?
    I am thinking its my ICM, can i rule out a boost leak or should i have that smoke tested before i buy a new ICM.
    also, if it is an ICM, which one is the bad one? front or rear.
    Thanks guys!
    B7 RS4...mmmm.
    Senior Member Two Rings joeS407's Avatar
    Dec 20 2007
    2000(B5) S4 Hibiscus red
    naperville
    Re: Please help finishing diagnosing my misfires...TIA
    did you change your timing belt and all that good stuff... i did and that happend to me it ended upt being that the belt got kinked and moved the timing so i was smashing exhaust valves with the pistons and needed to have the cyliderhead reground aswell. hope this helped and your problem isnt like mine. it cost $5500 to have the cyliderhead reground and new exhaut valves and labor
    Feb 26 2008
    Rockford, MI
    no, timing belt was done a while ago...30k miles ago. it better not be that!
    B7 RS4...mmmm.
    Veteran Member Three Rings Rajan147's Avatar
    Nov 23 2007
    Columbus, OH
    is it bad enough where you are getting a CEL or are these just silent codes?
    Before you start buying random parts, What plugs are you running, where they gapped correctly, what stage are you?
    B5 S4 AWE Stage 3 - sold
    Stage 2 Banner Advertiser Four Rings jaybquick@JHM's Avatar
    Aug 24 2005
    Lathrop, CA
    You need to elaborate more clearly. Are these missfires at idle or at high rpm under boost??
    Also what spark plugs are you using?? What are they gapped at?
    Have you been losing any coolant???
    Any cam sensor codes??
    JHMotorsports AZ tuner spotlight VIDEO
    Check out our 11 and 10 second passes on YouTube
    B8 S5 4.2l - JHM Stage 1 SC Kit (ET: 11.8 @ 119mph) -- B6 S4 - JHM Stage 2 SC Kit (ET: 11.1 @ 128mph) – JHM Nitrous (ET: 12.29 @ 117mph) - JHM Bolt Ons -ALL MOTOR (ET: 12.70 @ 111mph) -- B5 S4 - JHM RS6-R (ET: 10.8 @ 130mph)
    Nov 23 2007
    Columbus, OH
    jaybquick=encyclopediaS4
    Veteran Member Three Rings GetAwayFromMe's Avatar
    Jan 03 2008
    One million dollars all in pennies
    Iowa
    My car had crazy misfires at full boost when i first got the car. Bosh Platnums was my problem. Changed the plugs and once it had full power my turbo blew lol
    Feb 26 2008
    Rockford, MI
    Quote Originally Posted by jaybquick@JHM View Post
    no cam sensor codes at all...misfire is all the time, idle, boost, always. it wont let me get above 5 psi, like its in limp mode. not losing any coolant at all. plugs are autolite double platinums gapped at .028. the plugs were changed after this had started happening, same plugs that were in it before and never had a problem with them.
    if it were the plugs, i would assume multiple cylinders would misfire, not just cylinder 5. when i switch the ICM, the misfire moves, for the most part. thats why i was thinking ICM. what could be causing the Limp mode. I do get a CEL for the misfire. I was thinking boost leak at first, but the car still pulls same vacuum as before when it ran fine.
    B7 RS4...mmmm.
    Jan 03 2008
    Iowa
    If the missfire changes when you move the ECM than replace it. Each ECM controls one bank, if the misfire changes to a different bank when you switch it than you know that's the problem it's no brainer.
    Feb 26 2008
    Rockford, MI
    so i just replaced the ICM, car runs like a champ now! expensive, but took a whole 9 hours of diagnosing, and 1 minute to swap it out.
    B7 RS4...mmmm.
    Veteran Member Four Rings aaaudiprotein's Avatar
    Apr 17 2007
    2003 RS6
    Chicago Burbsss
    are u running lean? Vacuum leak?
    BLACKHAWKS 2010, 2013 and 2015 STANLEY CUP CHAMPIONS
    Windows 7 WAS MY IDEA
    Veteran Member Four Rings wdbdy2000s4's Avatar
    Oct 08 2008
    1998 pathfinder, 2000 s4
    MA
    here:
    Quote Originally Posted by Blue_S4 View Post
    Aug 24 2005
    Lathrop, CA
    Got your PM and was gonna reply but I figured I should check the thread first.
    Makes sense since something changed when swapping the ICM out.
