So I just recently purchased a set of Tein Basic coilovers and had them installed by my local mechanic. Actually, it was his workers that installed them and off the bat I have notice two very noticeable changes.
1. Headlight don't seem to adjust no more. Normally, when I turn on the headlights, they would do some kind of self adjustment and it's very noticable especially when I have it pointed to my closed garage door. Now I have turned them on and no self adjusting action, just nothing happening. I have check the headlight auto sensor lever in the front driver side and it seems to be put back in place just fine. Is there anything I can do or double check or put the car in a better positioning to see if the sensors work?
2. Coilovers seems to be a bit "bouncy" especially in the rear. I read on numerous threads before deciding to purchase these that they are a tad stiffer than stock, but as of right now they do not feel any bit stiffer than stock. They feel softer than kinda bounch a bit when I'm driving as if I just did the cheap ol' fashion cutting the OEM springs just to get the lowered look, but totally messing up the entire suspension. Is this normal? I have had them on for about 3 days now and already did an alignment and all.
If anyone has some sort of picture or link where I can see the proper assembly of the Tein Basic coilover setup, that would help me out alot or just type down all the parts from top to bottom of the shock.
for example: (rear shock assembly parts) OEM top mount > dust cover > bumpstop > etc....) I want to check again if those mechanic did it right. I know they were just bitchin all day about the car and hated to work on the suspension blah blah blah....
THANKS IN ADVANCE GUYS.
