Page 1 of 4 123 ... LastLast
Results 1 to 40 of 154
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    Engine Bay: Carbon Fiber and SUPER polished project!!!
    i thought id make this thread to cover my ongoing engine bay project.
    the plan: polish EVERYTHING metal and wrap EVERYTHING plastic in CF and hide all wires under custom CF panels.
    ive been laying CF by hand and polishing parts for a little while now. i though id share some of the stuff with you guys, as its all B5 parts i do...
    this is the motor setup:
    GT28RS eliminator
    3" inlet/3"maf
    AEB head
    Unitronic 440cc file
    Delphi 4400cc injectors
    034 High Flow Exhaust Mani
    3"test pipe to 2 1/2" catback
    NEW MOTOR SETUP:
    Kinetic T3/T4 50 trim (.63 4-bolt discharge with V-Band adapter) Now a Garrett...because the Kinetic DIED IN A MONTH!!!
    Tial 38mm WG
    ATP clone T3 side mount log manifold
    ATP BT DownPipe V-Band
    Greddy FMIC/custom piping
    Oil lines pieced together from ATP (man i hate giving them money)
    Custom inlet pipe
    Delphi 440cc injectors
    this is the intake mani i finished last month that i will be using on this:
    here is a close up of the polished valve cover with an 034 coil cover i laid carbon over (i didnt know they just sold them with CF at the time i made this):
    i just finished polishing this T3/T4 50 trim (its replacing my GT28RS Eliminator):
    before:
    after:
    some carbon fiber and polished parts installed:
    some pics of other stuff on the car i made (and am in the process of making):
    CF B-pillars:
    Radio Surround:
    Im working on this set of door trim right now (it hasnt been sanded yet):
    FINISHED THE TRIM:
    WRITE UP FOR HAND LAYING CF:
    here is an engine cover i cut to seperate just the part that covers the fuel rail/injectors/coolant pipe.....i polished a valve cover and am using a carbon fiber coil pack cover...so this piece will match the CF coil cover (and Carbonio intake)... here is the process of how i made this part:
    first i wrapped the part in CF cloth (2x2 twill weave):
    the back (not so pretty):
    this is the resin:
    just mix it 2:1
    then apply with a paint brush (making sure to go over it with the brush ALOT to get all the little bubbles out (this pic is before i spread it around):
    this is after the first coat dried...looks like shit, huh?:
    after the second coat:
    and after the third coat:
    also after the third coat:
    then i do the unthinkable!!!! i scratch the hell out of it with 220 grit sand paper:
    this is necessary because when laying resin by hand (as opposed to using vacuum bagging techniques) the resin dries kind of bumpy
    i start with 220 to REALLY get it as flat as possible, then rinse it off (looks nice, huh?:
    i then go on to use 320 grit, then 400, then 800, then 1000, then 1500, then, 2000, and lastly 2500!!!:
    however, only the 220 (to start with) then 600 or 800, then the 1000 are necessary ( i just went crazy because i just so happen to have EVERY grit you can think of..and the more you move up to just the next grit, the smoother it will be...but it isnt necessary)
    this is after i did all the sanding and rinsed it off:
    all that it needs now is a coat of clear coat. when the clearcoat dries i will use a plastic polishing or automotive clearcoat polishing product such as "Plast-X". after that it will be UBER glossy!!!!!!!!!
    this is the process i use to make ALL my CF parts......
    i will add a polishing write up soon (as i have another part to polish soon).
    i will update this often.....
    Dec 01 2007
    Markham, Ontario
    Re: Engine Bay: Carbon Fiber and SUPER polished project!!!
    great handy work =)
    gj man
    2015 BMW M3 Alpine White
    2013 Phantom Black RS5
    2012 Audi TTRS Black / Black - Sold
    Plus One
    Gabriel
    3255 Highway 7 East Unit 159
    Markham Ontario
    Cellular sales / repairs / unlocking / flashing - PM if you need help with anything
    Senior Member Two Rings Maki's Avatar
    Feb 29 2008
    A4 1.8TQ -96 S2 -93 BAT
    Sweden
    Good work! I'll keep an eye in the thread.
    //Marcus
    My Project
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    the crappy back kind of makes it look even more one of a kind. I like how the back looks, raw and fresh.
    TEAM|AXION
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Where do you get your cf material from?
    Also, thanks for the write up.
    Jun 01 2008
    Apopka, FL
    Quote Originally Posted by VTAudiA4 View Post
    probaly ebay, you can get lots of scrap CF and small 2x2 weaves like that for *cheap*
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    wow great job and can't wait to see the engine all polished and carbon fibered :)
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Nice write up and good job I wish I had the time to do all that.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Account Terminated Four Rings
    Aug 16 2007
    Buffalo NY
    sexy!
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    nice intake mani.
    CF looks great
    Sep 04 2008
    Columbus O-high-O
    Quote Originally Posted by offroader1006 View Post
    nice intake mani.
    i thought you would appreciate that :) (i got the mani from him then polished the crap out of it...)
    CF material is all from EBAY. i NEVER by ANYTHING for my car from ebay...but this is a little different....Resin is from EBAY as well.
    ill take some pics of some other recent stuff ive done lately and post them at the top....
    thanks for the kind words too. i think anyone can pick it up. i never even tried fiberglass first. i jumped head first into the "hard" stuff (my first piece..it was some A4 interior trim...came out great)...
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I've been wanting to do this for the longest while.....now that I've got my engine done, the interior will be the next project (just CF trim and shift surround)...
    When you hand wrap the plastic parts in CF, do you use some sort of Spray-on adhesive to get the cloth to stick? Sorry for the dumb question
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Oct 20 2007
    I think he just used the resin and then layered the material on top.
    Sep 16 2006
    '98 528i
    Looks like your right. Just found this link:
    http://diyautomods.com/2008/03/03/hello-world/
    I bet we're gonna be seeing a wave of DIY CF-trim threads in the near future.....i know for sure that I'll be doing it
    Oct 06 2004
    Minnesota
    Quote Originally Posted by JumboBlack1.8 View Post
    Definitely. You will all see more CF in my car as well
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Veteran Member Three Rings Sigma 3's Avatar
    May 23 2005
    Tricities Wa
    hmmmmNice work sir
    Originally Posted by FNK re getting more power from a 2.8 a4
    "Paint the exhaust and intake with Ceramic paint (heat repellent), thus increasing the exhaust velocity, thus less striction = more Power"
    Mar 09 2004
    99.5 A4 Avant, 01 allroad
    nw michigan.
    Just be sure that you get resin that won't discolor over time from the heat and temperature variations.
    Otherwise, looks great. FYI- it takes a lot less time to make a cheap vac bag setup than it does to do all that sanding.
    Jim
    I Do Werk.
    Sep 04 2008
    Columbus O-high-O
    you can put resin down and put the cloth over it. but the best way, that ive done anyway, is to just spray the piece with 3m headliner sprayglue (be sure to let the glue tack up first then put the cloth around it. also, AND THIS IS IMPORTANT, be sure to let the glue dry completely before putting on the resin or the spray glue can interact with the resin if its still wet)
    Sep 04 2008
    Columbus O-high-O
    BUMP for all the new pics i just added up top....
    this is what the raw cloth looks like
    Veteran Member Four Rings geeky's Avatar
    Nov 02 2008
    Boulder & Seattle
    holy crap. I'm REALLY liking that engine bay. If i may ask, where did you get all the resin, cloth, and materials, and how much did it cost?
    1989 Nissan 300ZX
    Lemons Race Car
    1999 Porsche 911 Carrera
    1-Off Widebody | LS1 Swap | AST 5200 2-way Remote Coilovers | blah blah blah
    2000 Mercedes Benz C230K
    The Daily | "VIP Build"
    2000 Audi A4 1.8T
    The New Track Build
    2006 Porsche 911 Carrera S
    LN Engineering 3.8L | H&R Suspension | IPD Intake
    Veteran Member Three Rings f15046's Avatar
    Oct 30 2007
    Griffin, GA
    If you could post a link to the Ebay auctions where you bought the materials, that would be great.
    I do work around the South East on your 1.8t or 2.7t, PM for more info
    ** 2001 A4 TQM
    -Fully built 2.0, GT3076, SPA mani, custom 6-puck clutch, Unitronics tune, Walbro 255, and much more
    Veteran Member Four Rings Charlescrs6's Avatar
    Sep 28 2008
    Boston, MA
    You don't vacuum bag do you? I want to do my mirrors but I'm pretty sure vacuum bagging would be essential for those.
    Current: ISO RS4
    Past: E46 M3 Convertible 6MT, B6 A4 1.8TQM Ultrasport, B6 A4 3.0Q
    May 23 2005
    Tricities Wa
    Quote Originally Posted by onemoremile View Post
    It would be great if you would do a vid dhowing how. Kind of a project vid on how to do projects
    Sep 04 2008
    Columbus O-high-O
    Quote Originally Posted by Charlescrs6 View Post
    not yet. ive done mirrors by hand..... within the next month or so i will be learning the vacuum process....i cant wait!!!!
    Established Member Two Rings The Russian's Avatar
    Dec 01 2008
    Boulder, CO
    very nice, i'll try Carbon next time, been working with fiberglass so far
    2001 A4 4.2L v8 quattro 5spd: 4.2L V8 swap | Tein SS Coilovers | Straight Piped side exhaust | StopTech Brakes | Custom aluminum radiator | Full Cage | much more...
    1983 Porsche 944: Daily Driver
    2001 Ducati 748: geared down | dry clutch | Termignoni
    Carbon Exhaust
    Sep 16 2006
    '98 528i
    Did you make a mold for those B-pillars or is that just an overlay of the existing piece (if so, how hard was fitment)?
    this thread is so inspiring haha
    Sep 28 2008
    Boston, MA
    Quote Originally Posted by 4inchMAF View Post
    hmm. One of my teachers is a CF pro and knows all the bagging techniques so I'm going to attempt to get him to help me. How'd you wrap the mirrors without creases?
    Current: ISO RS4
    Jun 14 2005
    Anaheim, CA
    Nice cf work. The finish is look really nice on the final piece. Good luck with the rest!
    -Charles@VMRWheels
    www.vmrwheels.com
    Brandon @ VMR Wheels
    Veteran Member Four Rings SoFresh's Avatar
    Mar 15 2006
    Seduction Motorsports 1955 Porsche 550 Spyder, Porsche 356 Coupe
    Scottsdale - Palm Springs
    Looks good, I just dont like how you used 2x2 twill CF on your custom mani/fuel rail cover when the rest of the CF in the engine bay isnt 2x2 twill. Other than that, looks good.
    Production Manager - Gunther Werks
    Founder - Seduction Motorsports
    Veteran Member Four Rings fred2ka4's Avatar
    Nov 26 2005
    Audi A4, Honda Pilot
    NM
    Nice work!!
    BetaAlphaTau member #18
    2000 Audi A4 w/ APR stage III & ...
    APR // GReddy // RACETEC // Bilstein // IForged // ECS Tuning // STaSIS // Neuspeed // H&R //
    And a whole bunch of other stuff ...
    http://i78.photobucket.com/albums/j9...4/fredscar.jpg
    Sep 04 2008
    Columbus O-high-O
    Quote Originally Posted by SoFresh View Post
    ill make another when i get some more plain weave... i have a bunch of engine covers i can hack up
    Registered Member Three Rings
    Aug 14 2008
    Salt Lake City, UT
    This is a part I want to make for my e36, I want to do them out of carbon though.
    My plan is to model them in 3d, cnc machine some molds out of styrofoam and bondo / gelcoat the molds. I could do them out of aluminum but for a 1 off it seems like a waste. Then I would vacuum bag them.
    I'm not really sure about how to nicely wrap that shape though with a minimum of seams and such.
    Integrated Engineering LLC
    Your source for fine quality VW/Audi Connecting rods and engine hard parts. Applications including: 1.8t, 8v, 10v, 20v, V6 and V8...
    www.intengineering.com
    Sep 16 2006
    '98 528i
    Anymore progress pics, especially polishing steps and products? I'm gonna start on my CF projects next week.....just need some more inspiration. Great work
    Sep 04 2008
    Columbus O-high-O
    ive been pretty busy doing interior stuff..... i can post pics of that if you like!!!
    im about to swap out my Eliminator 50 trim for a full T3/T4 50 trim setup.... so that is where most of my focus has been for the last week and this week..... this staurday im doing the install and using the shops polishing equipment to do some MIRROR finish stuff!!! cant wait!!!
    Sep 16 2006
    '98 528i
    Yup....I'm interested. I wanna see those pics too.....haha....I'm buying some resin and CF tonight, then starting hopefully by the weekend....would love to see what you've done
    Sep 04 2008
    Columbus O-high-O
    where are you getting your supplies from? be sure you get a resin that will not change color after prolonged exposure to heat....
    Sep 16 2006
    '98 528i
    I'm gettin the exact same stuff that you used....found a vendor on Ebay that supplies it. And I think I've found some good CF to use. Its a 36" x 50" piece....I'm hoping thats enough to do the trim and shifter surround, and maybe another small piece here and there
    Oct 06 2004
    Minnesota
    It should cover no problem.
    Instagram r_michals
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Good stuff man. Do you think you can PM me what all materials you are using/supplier? Im not so sure yet of how I am going to make my vacuum whether its a Food Saver or a homemade one with a vacuum pump. TIA
    Chris
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    May 23 2005
    Tricities Wa
    can you guys post a link to the vendor? and more pics please!!!
