Results 1 to 11 of 11
    Established Member Two Rings tj4891's Avatar
    Dec 10 2008
    NC/AL
    Performance chipping?
    I am looking to do my first mod and I have been thinking about getting a chip or exhaust. I have already learned a lot about the exhaust but now I want to find our more about getting a chip. With that said...
    With a completely stock car(check my garage for details) will I have to do any other mods to compensate for the power gain?
    Is it recomended if I plan on keeping my k03?
    People seem to say if your keeping your turbo then go with the closest dealer. There are only a handful of APR dealers and none near me. There is on GIAC dealer though. Not interested in REVO, too much cash. So should I just go for the GIAC?
    Any information and advice is welcome thanks!
    Found these helpful, but not all questons answered.
    http://www.audizine.com/forum/showth...rformance+chip
    Veteran Member Four Rings njm23's Avatar
    Feb 28 2007
    04 a4 USP ; ATS
    Re: Performance chipping?
    If you plan to stay with your ko3 setup, then I would suggest going with the generic tune. Unless the custom tune is the same or of a lesser price there is no point. GIAC is great. No you don't need anything else to support this. Optional stuff like exhaust/boost gauge ect.. but nothing required.
    Senior Member Two Rings Stumanbmx's Avatar
    Nov 04 2007
    '00 A4 1.8TQM
    Minnesota
    Most will tell you to search but I'm feeling nice.
    Quote Originally Posted by tj4891 View Post
    Yes, an upgraded DV is pretty much a necessity. A 710n should work just fine.
    Definitely, best bang for the buck for a K03.
    Yeah, most people prefer GIAC for it's more aggressive tune anyways. I have GIAC myself.
    Dec 10 2008
    NC/AL
    If I go through with a chip and later want to get exhaust, should I go from 2.25'' piping to 2.5" due to the increase in power?
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Do a chip first. You'll love it. Then upgrade the exhausts. 2.5" is perfect for the K03. Combine that with a muffler/resonator of choice and your set.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Dec 05 2007
    Best advice is to figure out what you want to do with your car, then go from there. Meaning if you plan on going with a bigger turbo later on down the road. And if you are like most on this site, the mod bug will come and bite the crap out of you once you get started. Take it from one whom only had plans for window tints, stereo upgrade, and wheels.
    What I did was figure out what I want to do with my vehicle. I eventually want to big turbo kit (GT3082r or bigger on a 2.0 block). I thus chose a suitable company (Eurodyne/CTapp) to chip my stock ECU to keep me suffice till the time comes, as to upgrade to a BT file will cost me ~$250 from what I already paid (other companies only have files for turbo kits up to a GT2871r). As for my exhaust, I went with a Milltek as the diameter is 2.75" (plus the sound note is very soothing resonated) and anything smaller would be too restrictive for a big turbo application (that is one reason why many go 3" exhaust on thier stock turbo, as they do not want to do an exhaust all over again). Placed on a Labree High flow Cat Converter to complete my exhaust system and now I drive like this .
    A good route is to maybe look into Unitronics (they have many files from stock turbo to BAT). They are very good and if you eventually get the mod bug, then you can always just go right back to them for a cheap upgrade instead of dishing out $750+ as a new customer. Or you could just keep an eye open in the classified for someone parting thier flashed ECU and still keep the ECU you have as a spare.
    When flashing the ECU, you will need to upgrade the diverter valve, as the stock one can not handle the extra pressure and will eventually rip. Forge is a very like dv by many on this site (I also run with the Forge 007) but there are many others. Or you could just get the 710n dv (cheap route, yet effecient). It would be recommended to get a boost gauge to monitor your engine and spark plugs will need to be changed.
    Dec 10 2008
    NC/AL
    I don't ever plan to change the turbo. With that said would the top option be the correct chip for the f99 with the facelift?
    http://www.giacusa.com/programs.php?mpid=54
    Dec 05 2007
    That is correct
    Senior Member Two Rings M_souren's Avatar
    May 03 2007
    2001 Audi a4 TQM
    Bridgewater, North Jerz
    go for unitronics or dahlback for ecu tuning. they both adjust for timing rather then just turn up the boost.
    Audi's and Vw's galore
    Veteran Member Four Rings lowandslow4now's Avatar
    Jul 12 2008
    Cumming, GA
    Are you AEB if you are I will probably have a Unitronic stage one ECU available within the next couple of weeks.
    Now 2001 B5 S4
    Former B5 A4, 034 Stage 3 BT, Unitronics,H&R,etc,etc
    Sep 17 2006
    07 cbr600
    messagetoshorttojustputheadbang
