Results 1 to 40 of 40
    Senior Member Two Rings coyote's Avatar
    Jun 07 2005
    Jacksonville, FL
    Carbon Fiber Interior Trim
    Well it all started a while back when I saw a car online with carbon fiber interior trim. Then I started researching where I can buy it. It turns out that when my car was manufactured it was not an option. So I decided to make my own. I guess I could have gone with some of that stick on stuff, but I wanted the look and feel of the real thing. I have some experience with fiberglass and carbon fiber is basically the same thing except with carbon you are showcasing the material instead of hiding it.
    The trim pieces that I covered have a rolled edge on both top and bottom. Also the front doors and the dash trim pieces are curved. Carbon fiber is typically used as a reinforcement layer in structural parts. So when you wet the carbon fiber it tends to stick up due to the structural properties of it. I wanted a fairly heavy ounce material so the fibers would show though. After talking to some people about the project it was recommended that I vacuum bag the pieces of trim in order to roll the carbon around the rolled edge of the parts.
    Let me say that this project requires a lot of time and patience. With that being said I needed to remove all of the trim from the door cards and from the dash. Okay this should be easy right? Guess again…the doors yes…it was cake but the dash is another story. Four or five hours later the trim is finally out but I needed to put it all back together because it’s my daily.
    Now with the trim removed I made wood bases for the parts to sit on so I could vacuum bag them down. I took 2x4’s and traced the shape of the part on then, took it to a band saw and cut them out.
    After that all of that the materials could be cut. The carbon fiber, peel ply, blotter and the bag itself. The real trick is getting the weave lined up straight without any kinks, bends, or other imperfections. I left about a 1/2” hang over the part on all sides and then trimmed it later once it was dry.
    After the vacuum bagging process is done I built up about 3 or 4 layers of resin and wet sanded in between each. Then once I was satisfied with the finish I applied 3 coats of clear coat and wet sanded with 1500. I finished up with buffing compound to get a clear glossy look.
    The before:
    The after:
    Jun 04 2007
    01' A4 1.8TQM;15' Wrangler
    Austin/DFW, TX
    Re: Carbon Fiber Interior Trim
    Wow, good shit. You should make a detailed process on how to do that CF lay down. Im sure a lot of people would be interested including myself. I have that same boost guage and its in the same spot! lol.
    BetaAlphaTau Member #12
    01' A4 1.8TQMS 5spd swapped
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Three Rings big_greasy_taco's Avatar
    Apr 28 2008
    Houston, TX
    That looks great, a diy for this would be choice. As mentioned above, TONS of people im sure would like one.
    Active Member Three Rings 4inchMAF's Avatar
    Sep 04 2008
    Columbus O-high-O
    Quote Originally Posted by big_greasy_taco View Post
    im making a DIY for this right now!!! ive done about 15 sets of trim so far...... i have about 6 extra full, finished sets laying around right now LOL
    OP:this looks great. i did all mine by hand...i REALLY want to get into vac. bagging....where did you get all your bagging stuff?
    have you done this before? it looks nice. ive been doing engine covers, radio surrounds, ash tray covers (basically anything i can get carbon fiber onto )
    here is an engine cover im almost finished with (its actually just the part that covers the fuel rail/injectors), i still need to clear it and use some "Plast-X" polishing coumpound on the clear:
    oh....what kind of clearcoat did you use?
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by 4inchMAF View Post
    Damn, can you like send me some helpful links? I wanna get in on this.
    My 5-Speed Swap DIY
    - B6 USP
    Veteran Member Four Rings oneohone's Avatar
    Nov 13 2007
    Baur TC2 / W221 S600
    Dallas, TX
    Quote Originally Posted by biketsai View Post
    Hell yeah, make me some shit.
    Daily - 00' Audi A4 1.8t Quattro 5mt Laser Red Avant
    In.Progress - 00' A4 2.7t Swap (w/ K04's)
    Jun 04 2007
    Austin/DFW, TX
    Quote Originally Posted by PiMPMAN101 View Post
    Lol, we should chip in on a Food Saver vacuum thing
    My 5-Speed Swap DIY
    - B6 USP
    Nov 13 2007
    Dallas, TX
    ^For real.
    Hit me up tomorrow, I have to go to Plano anyways, so we'll throw on that grill and snap some pics.
    Jun 04 2007
    Austin/DFW, TX
    ^For real.
    Cool, well I guess just gimme a call whenever you are heading this way.
    My 5-Speed Swap DIY
    - B6 USP
    Nov 13 2007
    Dallas, TX
    Alright.
    Jun 07 2005
    Jacksonville, FL
    PM's sent
    01 Audi A4 quattro 1.8T
    Veteran Member Four Rings JumboBlack1.8's Avatar
    Sep 16 2006
    '98 528i
    Boston/West Hartford, CT
    I'm gonna be doing this VERY soon....excellent work
    2000 Audi B5 S6 ** 4.2L 40v S6 6spd - http://www.audizine.com/forum/showth...n-s6-4-2L-swap
    Veteran Member Three Rings Naudi_Mat's Avatar
    Nov 02 2007
    2008 S-Line A4
    Denver
    PM me too
    Veteran Member Four Rings VTAudiA4's Avatar
    Oct 20 2007
    Go to youtube and google. I looked up some DIY's and it does not seem too hard (depending on what you are overlaying). Also, its easy to overlay but to create a an all cf piece takes a lot more work. Either way, with practice it can be done. I also checked out the prices on ebay and the cf material is not expensive. The resin is costs a bit more but nothing terrible.
    Jun 07 2005
    Jacksonville, FL
    Quote Originally Posted by VTAudiA4 View Post
    I would have to agree. There is a lot of useful information on youtube. The materials are fairly reasonable but you will also need a vacuum pump. The biggest thing is you need time and patience!
    Jun 07 2005
    Jacksonville, FL
    PM's sent...
    Thanks everyone for the kind remarks.
    Oct 06 2004
    Minnesota
    Good talking to you the other day on the phone Greg.
    Instagram r_michals
    '12 Q7 TDI- Glacier White
    Jun 07 2005
    Jacksonville, FL
    You to Rob. Just let me know if you guys want to go ahead with what we talked about.
    Jun 07 2005
    Jacksonville, FL
    I'm at it again. Starting a new set.
    Oct 06 2004
    Minnesota
    Awesome Greg! Is this the set you bought from A&P?
    Instagram r_michals
    Jun 07 2005
    Jacksonville, FL
    Quote Originally Posted by A4Rob View Post
    You got it!!
    Apr 01 2005
    one wagon one truck
    Michigan
    Wow, very sweet. I may have to try this at some point.
    Active Member Three Rings AP-Specialties's Avatar
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by jaustin View Post
    Let me know if you need a set of trim. We have a couple sets left
    A&P Auto Specialties, LLC • 1960 County Road 90, Suite 100 • Independence MN 55359
    Veteran Member Four Rings m5racer's Avatar
    Nov 20 2006
    looks great! U did a smashing good job. But fuck me man, that is the uglyest interiour i have ever seen on an a4 (colour wise). All that grey must make your head spin.
    01.5 A4 1.8t sport
    Veteran Member Four Rings flynnr's Avatar
    Sep 22 2008
    2015 Q7 TDI Prestige/S-Line
    Minnesnowta (Roch)
    ^ true, but i think that the CF trim really adds a nice break line in it all... can you imagine having the cf portions in brush aluminum? ha it would practically blend right in... looks like an elephant
    Oct 06 2004
    Minnesota
    I like the gray interior
    Instagram r_michals
    Veteran Member Four Rings jrock's Avatar
    Oct 02 2007
    Lone Tree, Colorado
    AP-specialties, you guys sell the pump for that? Or were you just talking about the trim. i just ordered my first batch of carbon fiber and resin the other day.
    Mar 15 2008
    A few Audis
    Independence, MN
    Quote Originally Posted by jrock View Post
    We sell used Audi Parts. Let me know if you need a set to play with.
    Sep 28 2006
    Lexington
    Quote Originally Posted by coyote View Post
    After that all of that the materials could be cut. The carbon fiber, peel ply, blotter and the bag itself. The real trick is getting the weave lined up straight without any kinks, bends, or other imperfections. I left about a 1/2†hang over the part on all sides and then trimmed it later once it was dry.
    The before:
    The after:
    You should makes these for people!!!! I'll pay for it!
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Oct 02 2007
    Lone Tree, Colorado
    you should definetly not quote his whole post when you post.
    thanks ap- will do
    Veteran Member Three Rings leon's Avatar
    Nov 28 2004
    A4 1.8T Quattro/VW Polo 6N
    The Netherlands, Europe.
    Nice!
    Where do i buy the vacuum thing.?And how does it work?
    A4 1.8T QUATTRO
    Garret GTRS turbo/Forge DV007/Bosch 440/Bosch 044 fuel pump/HT 3" SS TIP/HT 4" SS MAF/Autobahn FMIC/Carbonio CAI/Racekat/2.5" SS HT Exhaust/Eisenmann Muffler/034 High Flow manifold/Mocal plate,Setrab oilcooler/Porsche Brakes/Eibach Pro Street S/19"BBS Le Mans
    Veteran Member Three Rings JaVa's Avatar
    Jan 07 2007
    01 A4 2.8, 85 Yota, Isuzu
    Quote Originally Posted by leon View Post
    Nice!
    you can get them all over, its a vaccume pump. kinda like the opposite of a compresoor. just pulls the air out.
    OP-great work! ive just started to dabble in CF and it looks like your doing a great job!
    NWQuattro - NorthWest Audi Group
    ----01 A4 2.8 QS Tip |GIAC|Zapco|Alpine|Dension|Tint|
    Oct 06 2004
    Minnesota
    Quote Originally Posted by JaVa View Post
    You can also rig one up to work with a normal shop vac
    Instagram r_michals
    Jun 07 2005
    Jacksonville, FL
    I always keep one close just as a backup. Only had to use it once a long time ago when I couldn't draw the bag down.
    Registered Member Four Rings D.C. Designs's Avatar
    Feb 28 2008
    Many
    alexandria
    wow looks really good
    Sep 23 2007
    If you don't mind me asking. What did you pay for that roll of carbon fiber and where did you get it?
    Oct 06 2004
    Minnesota
    Quote Originally Posted by jturnbull View Post
    I got a yard on eBay for $20. 2x2 twill too
    Instagram r_michals
    Mar 26 2005
    01 A4 1.8t avant; 04 B6 S4
    All over the Bay Area
    kinda off topic, what kind of ipod hook up is that?
    thanks!
    TEAM|AXION
    Jun 07 2005
    Jacksonville, FL
    Quote Originally Posted by speedydragon View Post
    Go to mp3yourcar.com for the Ipod integration.
    I got it locally but you can get it pretty much anywhere.
    Veteran Member Four Rings anmagro's Avatar
    Sep 14 2008
    omg man, that CF totally changes everything. it went from the most dull looking interior to lookin real nice with something as simple as that. good luck with the rest if you do more cf.
    Black On Black 98' Audi A4 2.8L 30V 5spd. Quattro "Esabell"
    BBS RK's - Zimmerman - Vogtland Sports - Thrush Welded Cat-Back - DDM 6000 - Reigar RS4 - K&N Spectre - EbaySS - SpeedTuning Stage I
