Results 1 to 25 of 25
    Senior Member Three Rings Greek Yayo's Avatar
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    stage 2 unitronic
    i got stage 1+ unitronic... is stage 2 upgrade worth the 50 bucks plus the money for the 380 injectors?
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    Re: stage 2 unitronic
    If it's like Revo Or Giac, it's a nice little kick.
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    definatley noticable tho?
    Mar 21 2006
    Lakeland, FL.
    A little more boost and timing, yes noticable.
    I'm back bitches!
    Veteran Member Three Rings youngspeed's Avatar
    Jan 15 2005
    RS4 Avant, A4 1.8TQM Avant 05, EVO X 08
    Spot marked X
    its very very good!! Unitronic has done a very good job with with the 1.8T maps
    SQ5 B8 white
    REVO STG 1+ SINGLE PULLEY,APR CPS, APR 3.0T CARBON FIBER INTAKE, 034 THROTTLE BODY SILICON HOSE, 034 REAR ARB, 034 TRANSMISSION AND DIFF MOUNTS, KW V3 COILOVERS, AP RACING BBK, LEYO V1 PADDLE SHIFTERS.
    PAST RIDES - RS4 B7 MISANO RED. GIAC TUNED, MILLTEK.y
    2015 SUBARU WRX STI, ECUTEK TUNED.
    EVO X. ECUTEK, HKS EVERYTHING
    GTRS BT A4 1.8T TQM UNITRONIC TUNED
    A6 C5
    INTEGRA GSR
    Veteran Member Four Rings Smiley's Avatar
    Sep 29 2007
    2002 Audi A4 1.8TQM
    Dubai, UAE
    Yes. Its worth it.
    Unitronic has good files too, your car will pull so much harder!
    Veteran Member Four Rings chadb2434's Avatar
    Oct 07 2008
    East Texas
    Si
    02 A4 3.0Q6MT
    -chad
    Oct 22 2005
    Reppin the Mitten.
    with all this unitronic talk, it makes me wonder if unitronic can do better with BT files then lets say Revo or APR...
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    for the 380 injectors would i need spacers???
    Veteran Member Three Rings davidlizard's Avatar
    May 01 2008
    2004 A4 ultrasport 6speed
    Winter
    I like it!!
    Unitronic stage 2+ / Borg Warner K04 / Milltek / ATP 3" testpipe / Racetec FMIC / Forge TIP / Carbonio / Forge DV / 386cc / 034 25mm rear sway /Joey moded / Podi / JHM 350mm BBK & SS lines / STaSIS street sport/ Michelin Pilot Super Sport / ECS Tuning lightweight flywheel + RA4 clutch kit /
    034 engine & trans mounts / 034 snub mount / 034 front & rear link / Apikol rear diff mount / JHM solid short shifter
    Veteran Member Four Rings Undisputed's Avatar
    Jun 29 2008
    05' A4 USP, 00' Suburban, 07' Tahoe
    Quote Originally Posted by Greek Yayo View Post
    Which injectors do you have?
    05' USP 6MT-REVO Stage II- Racetec- Stoptech 332- OCarbon Fiber Interior Trim- B7 RS4 Steering Wheel- VMR Boost Gauge- Siemens 380's- Bailey Motorsport DV- NGK Copper Plugs- LED tails- and a few other things
    -Damon-
    USP CLUB MEMBER #927
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    now i got stock and ima be going to 380`s
    Jun 29 2008
    Check with Unitronic about their recommended brands. But I think that the only one that'll need spacers is Siemens. You should be fine with Genesis or TT's.
    -Damon-
    Senior Member Two Rings Alphazuzu's Avatar
    Oct 05 2008
    Holly Springs, North Carolina
    Im about to go UNI stage 2 and im expecting a huge boost (im at 1+ now). I have the testpipe (installed) and siemens 380cc's. I have been recommended to get a new clutch system and possibly cooling to compliment this upgrade since it will be pushing the K03 to its up-most limits. So in all it is actually not just 50 bucks more and injectors, your going to want to do some preventative and complimentary upgrades so the tune can run to its fullest potential. if you get there before I do let me know what you think about the tune.
    Veteran Member Four Rings JMRQuattro's Avatar
    Jul 04 2008
    Seattle, Washington
    Damn i already have a test pipe installed, so when i get my chip i might just buy the injectors and go with Uni stage 2 right away. Seems like most of you are wanting the upgrade anyway.
    - Justin -
    Jun 29 2008
    I'm stock right now and I'm going REVO, (maybe Uni since I'm hearing all this stuff though). I'm gonna go straight to Stage 2. Injectors, testpipe, DV, and FMIC. Although to truly be at Stage 2 I'll need a full exhaust. It's alot more than just the software.
    -Damon-
    Jul 04 2008
    Seattle, Washington
    ^^ I've already got the test pipe, full magnaflow 3" exhaust, and hyperboost DV. Is the FMIC a requirement as well for stage 2? Cause if it is then i need FMIC and Injectors, but if not i just need injectors. And i'll probably get the TT injectors.
    - Justin -
    Dec 18 2006
    03 A4 1.8t | 04 IB M3 SMG
    Hanover, NH
    FMIC is suggested
    Now: RNS-E | Debadged | GIAC 1+
    Soon: Caractere front and sides | S4 Rear | S4 Doorblades | Bi-Xenon E-Codes
    Future: GTRS BT Kit | Tip Tranny upgrade for BT Kit
    Jul 04 2008
    Seattle, Washington
    ^^ Now when they say suggested, do they mean strongly suggested because it will hurt your car without it? Or do they mean you just won't get maximum power gains out of it without one? Cause if it's option number one i think i can wait for the FMIC since getting MAXIMUM gains immediately isn't my biggest concern.
    - Justin -
    Veteran Member Four Rings downhillracer's Avatar
    Aug 20 2007
    97 Jeep Wrangler
    Costa Mesa / Mammoth Lakes
    the stock intercooler will heat soak very fast running that much boost out of the little hot air pump (Ko3) ... so they say strongly recommended but in my opinion id say its a must because once you heat soak your intercooler you run the risk of pre-ignition since stage 2 runs a lot of timing.... although the computer will compensate for the heat soak (via the IAT and the knock sensor) Id still say its a must if you want the most out of your tune!
    Jul 04 2008
    Seattle, Washington
    cool, good to know. I want to make sure i have all the information sorted out so i know what i'm getting into before i go in there and find this all out when i want to do the tune haha.
    - Justin -
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    For those with Stage 2 Unitronic already, what brand 380 injectors did you use??? and are they the best for the unitronic stage 2 software?
    Veteran Member Four Rings a4wd's Avatar
    Jul 27 2004
    B6 1.8TQM 5speeeeeeeed
    Bay Area 925
    FMIC is not recommended, its NEEDED
    another stereotypical Audi
    Aug 14 2008
    Audi A4 1.8T
    Suffolk, New York
    not for unitronic... it wuulda said it on the website
    Jan 10 2007
    VA
    you don't 'need' an FMIC to run any injector file on a B6.
    An FMIC is helpful in preventing heatsoak and keeping the car consistant. You will notice a difference with the injectors alone, and will also notice a difference if you upgrade the intercooler later on.
